Even though my T@b is winterized and sitting quietly for the winter season, I wondered about whether or not the Alde can keep the T@b warm enough to use for winter camping. I mean real winter, where snow is on the ground and temps stay below about 30 degrees. The Alde could run on electricity while driving, and on shore power at a campground. Would it be able to both keep the T@b warm enough to be comfortable and keep the water lines and holding tanks from freezing? My main thought was that if we chose to go south for awhile, we would have probably two days in the cold winter climate before we got far enough south to no longer worry about freezing, and I wonder if the T@b would survive. I guess another solution would be to leave in winterized until we arrive at our southern destination, then re-winterize before heading home. But could the Alde do the job?
                2016 T@b S Maxx
2011 Subaru Outback
Rockford, Illinois
0 ·
First, I'd not have fresh water on board when it's consistently below freezing. The Alde may keep the internal pipes from freezing but definetly not anything external. I'd have it in winterized mode.
Last year, before I could head south, I was stuck for a week in 40/27 degree weather and then a week in 10 degrees with a stiff 30mph wind. I was winterized and carried water internally. The Alde did fine the first week but not the second. With all the little cold air leaks from the AC and fridge vents I couldn't get much warmer than 55-60. If one had vent covers one might get better. I didn't dewinterize till I got south far enough where I had consistant above freezing temps.
I wouldn't trust the plumbing to stay thawed, however, and the outside holding tanks will definitely be at risk.
Verna - I made a sabel style ac cover yesterday. Was pretty easy.
Taken from THIS thread.
2011 Subaru Outback
Rockford, Illinois
http://tab-rv.vanillaforums.com/discussion/630/for-every-ledge-theres-a-purpose#latest
As a general rule I think it's considered 68-72.
