I prefer headlines (titles) that provoke and make you guess a little so was going to title this thread "Show Us Your Pole" but knowing how some of you might interpret that (you know who you are), I had second thoughts.
Tried many varients - liked Jenn's fishing rod holder but couldn't find one that fit painting poles and held one firmly in place) - Ended up with this config. Holds up well even in the wind... In these photos I'm experimenting with a cheap, non-powered digital tv antenna clamped to the top plate but I normally use it with a magnitized cell phone booster antenna...
The basic parts are ... Cheap paint roller extender pole - Battery connector - Junction box cover - Velcro ties - Ball bungies
... The battery connector screws onto the pole and the junction box cover attaches to that with a wing nut to provide a base platform. Ball bungies hold it in place by attaching to the T@B handle ring and a little camper stake at the bottom. Small velcro ties hold the cables in place.
Additions are ... A coax to tv antenna connector - Allows me to connect/run a ground wire (coax cable) down to the T@Bs ground wire. In the cell phone booster thread it was mentioned one needed a grounded reflector plate to get the best boost. I haven't noticed any difference in using it or not but so much depends on area and base cell signal that it might just be the areas I've tried it in.
So far it's been very stable even in 40 mph winds.
(I especially like that cute little phrase there on the back of your Tab.) B-)
Now, if I was a sports fan I might feel differently. Had a neighbor in one campground that ran his generator 8 hrs a day on sports days so he could fire up his big tv.
Pole sits right above my guitar case.
What happens to them over that time to change things?
The reality though (based on experience to date) is I probably won't use the pole very much if ever - Don't watch TV and 95% of the time I have a decent cell signal. When not, I have absolutely none so the cell booster won't help anyway.
Just a nit, but I believe digital and analog signals are for the most part, both line of site. The difference is that the digital signal has all of the bits (ones and zeros) compressed and modulated on the carrier wave. It's mostly all or nothing on the receive end for a digital signal. If the digital signal is weak you won't see anything, or you might see a pixalated image (No pun intended) if your TV tries to make sense of the weak digital image with some missing ones and zeros. The analog signal seems to go a bit farther because some of a weak signal can actually make to your antenna in the form of scan lines. This is when you see snow on the analog signal.
TV signals operate at 50 mhz to 800 mhz and it is rare to see signal propagation in that frequency range. Not impossible, but rare. Propagation is essentially RF bouncing off of the ionosphere and coming down somewhere distant (i.e., not line of site). That is how radio signals can get from one side of the planet to the other side of the planet. A good example is ham radio and short wave radio on the HF bands. Propagation is more common on lower frequencies (i.e., 3 - 30mhz). TV signals operate on VHF and UHF bands.
Of course a pixalated image on a computer is usually due lost packets in a packet switched network, but you will see something similar.
Next you need to somehow install it as an internal periscope type of system. There's room behind the toilet, it would just need a good gasket on the outside...
2014 T@B CS Maxx
Martha Lake, WA
If I was a sports fan I'd probably watch TV - I'm not and I really can't say much good about tv news (no wonder most are so ill informed) - The few entertainment programs I've found worth my time aren't really worth the effort of the set up, channel scan. Much more efficient just to hit the net or download what I want.
Last year, when boondocked (BLM) south of Quartzite, there were several lanes back in off the entrance. In some cases you can't cross over because of washes. There was a camper out in my general area with a flashing light on a pole. Ended up being my guide. Have been going to make one ever since.
