I will be heading out on a trip to the Gulf (Alabama & Florida) next week from Chicago. It is currently above freezing here (chicago) so I will de-winterize before leaving. However we will not be returning until January and it will most likely be below freezing when we get back.
Anyone have any tips for winterizing mid trip? We will definitely be using the water tanks and system during the trip so leaving it winterized isn't an option. I have never winterized as our T@B came winterized when we picked it up from Pleasant Valley in October.
                1 ·
You can pick up a small air compressor that runs off your TV battery or get one that plugs into your 12v outlet on the T@b. These use quite a bit of juice, so if you use your TV, keep the TV running or if you use the 12v outlet, make sure you are on shore power. These are also nice for keeping your tires topped off easily as fewer gas stations seem to have air available these days. If you get one that does not have a way to control pressure, make sure you connect it to your water pressure regulator to the compressor hose and then blow out plug to the T@b. I use this compressor when I travel and picked up a longer hose and extra fittings, including one for filling the tires that has a tire gauge attached (very handy)
You should be able to pick up RV antifreeze at either a local Walmart or auto parts store. In the worst case scenario, either ask the campground or order via Amazon and they will, quite often, if you mark your shipping directions with your campsite number, deliver right to your site.
In these cases, it is always better safe than sorry. I have been watching Joe Bastardi's long range forecast and winter is going to flip from warm to cold in January as the El Nino begins to recede.
I also blow out and add anti-freeze as @PXLateddescribed.
http://tab-rv.vanillaforums.com/discussion/2035/winterizing-sanitizing-pump-made-simple#latest
