Pop-T@B
Member Posts: 199
I like the Lagun table mounting system, except for two things, the high price just for the mount with no table and you still have a post in the middle of your bench. We have been using a fold up table and it works fine, but I wanted something that was there when you need it and out of the way when you don’t. So here is what I did in my T@B Max S. I used a Barkan Flat panel TV mount model #34F which can support 77lbs ($50.00) and the top from a Mainstay folding table I was using from Walmart ($15.00), and some hardware ( under $10.00).The hardest part to this whole process is you will need to reinforce the wall below the TV, there is a piece of ½” plywood in the wall at the bottom of the hole where the TV mounts and behind the support rail for the bench at the bottom of the wall. The wall between the two is just paneling. If you like this idea and need more detail on how I did the install send me an email for more information.
Thanks, Shawn
2016 M@x S Sofitel - The T@bahoula
the table can be removed, if needed with one screw, and yes it does swing around and could be used as extra counter space.
Happy Trails Y'all
Sterling, VA
I could cut down the table's center support post. This would allow you to make the table height whatever you wanted it to be, but you would no longer be able pivot the table to store it against the wall. If you go shorter in height, with this size ( 26"L x 18" W) table top, it will hit the seat cushion when you go to store it. You can do this is you don't mind removing the table top and storing the top somewhere else. You could also go with a smaller table and mount the arm lower on the wall. I was looking for easy table set up and a easy way to store it, with the table I already have. The added 3" in table height is a sacrifice I was willing to make, for the convenience I gained. This is something you would need to decide to see if it would work for you.
What of you lower the mounting. Could you remove the cushion stow the table against the wall then wedge the cushion back in place?
Pxlated, I looked at that location, just not enough room for the mounting base. I do have an update for you. I took dalehelman suggestion about cutting off the center mounting post. So I took it out to the shop, cut out 3" and welded it back together. The table height is now 28", same as the factory table height. It will still stow against the wall it just presses down on the seat cushion some. This may work better when towing down the road to keep the table a little more secure.
dalehelman, Thank you for the suggestion, it worked out great
! You know how the old saying goes " sometimes you can't see the forest for the trees". It's always better to get a few other sets of eyes on something to get it right. Thanks!
Here's a few updated pictures with the shortened center post
(formerly a 2013 T@B Q M@X); 2015 Jeep Sahara JKU (Max Tow)
Toronto ON Canada
