Was wondering if it would be possible to install the SeeLevel system on a 2016 T@B Max S? One big problem I would assume is the undercarriage being covered. Could a trip to the Factory be advantageous or overly costly? Would be nice to at least know your water levels (Fresh Grey & Black).
South Carolina
0 ·
John - check this article out. Guy says the SeeLevel uses adhesive strips that attach to the outside of the tanks. Hmm, maybe a retrofit is possible after all.
http://www.modmyrv.com/2009/01/12/rv-holding-tank-monitor-system
Will try calling the factory.
South Carolina
South Carolina
South Carolina
I'll tell on myself that I finally had to call tech support for my Tailgator portable satellite dish. The tech, such a patient young man, caught one of my comments as I was running a temporary cable out the door. I said "Now I just have to connect the cable to the rear of the TV." Oops.....I have an HDMI cable from the receiver to the TV, so the cable goes to the rear of the receiver, is what he told me......<Verna hitting forehead with palm of hand>..... Tailgator now works....
South Carolina
I'm guessing these type of installs are all done on Fridays as I recall as they do set aside some time to do this type of retrofit at the factory. I'd like to put one on my trailer too and might schedule it during the Rolling Home event in Ohio next summer or possibly drive down in the spring time.
If not, I might even attempt an install (in warmer weather) as it doesn't seem too difficult other than positioning/attaching the sensors on the tanks and getting the wiring up into the trailer and attaching them to a 12 volt feed inside the trailer, mounting the gauge, etc. The article above describes the unit well and by cutting off the strips (proportionately to the tanks), they sync themselves in when the unit is activated. This would be a handy item and allow one to plan ahead (dump gray/black water & fill fresh water tank, etc.) as needed.
2016 M@x S Sofitel - The T@bahoula
Thanks
I think why ours would be a bit more expensive is the the "26's have the undercariage covered. Marvin at the Factory said for the Fresh Grey and Black it would be $120 for parts $90 for Sensors and $5 for wire. Again these were his estimates as they had not done one. Then $150 per hour he figured 2 1/2 to 3 hrs. Would be nice to have but I think we will spend the $500 or so on travel and fun.
Again apologizes Mike for the extra work you had to do.
South Carolina
South Carolina
I ordered the SeeLevel II kit from Pleasant Valley, just received it today. The Kit was $210.00 with shipping. I started the install today on my 2016 Max S, so far I have the wires ran inside the RV, the hole cut out for the Monitor and have it mounted. Cutting the hole was tricky do to the bundle of wires behind the wall. You need to make sure to keep them out of the way when you are cutting the hole. I still need to mount the tank senders and run the wire up thru the floor, hope to finish this Friday evening if all goes as planned. I will post some picks and time spent once I am done.
