goal is to boondock using only solar. I have a Zamp 200W portable and group 27 house battery. My geek friend suggests a 2000W pure sine wave inverter (peak 4,000W). Would like to be able to run the A/C a few hours and very small microwave (separately). Your thoughts on (1) is this a realistic goal and (2) what brand and size inverter?
0 ·
I have a 400 inverter connected directly to the battery and 120watt solar (group24 battery) and I have no trouble charging my computer/iDevices and keeping my battery charged on a nice sunny day.
Great information.
In other words, using the TV as a generator of sorts. If used sparingly, like a couple times a year, only in the hottest days...
Thoughts?
Then the continuous operating power at maybe 800W or 900W (guessing here) translates to @ 70A at 12V.
Most automotive generators are intended to output much much lower continuous amperage than that.
Then there's what Jenn said...
ChanW, I just assumed that since they are so readily available, and as large as 4000W, that any car could handle the draw.. But maybe not, maybe they are used in a different set up?
To to me it seemed attractive to have a small inverter (plus install a hard start cap on AC) for the unpredictable/unavoidable hot day here and there. With generator you had to lug something that's heavy, plus a gas can, some oil, etc.
I would be really surprised if a 1000w inverter would handle even a small a/c starting amps and would think it extremely likely that you would need at least a 2000w inverter, although it would be an interesting experiment. Xantrex, which is widely respected in the power world, has a 2000w true sine wave inverter but it is a little over $350. You would have to also look at upgrading your batteries to support this use.
People who are FT RVers don't consider a/c attainable or sustainable for RVs yet, without a generator or shore power. These are rigs with huge battery power and equally large solar set-ups.
Now I think we might be getting down to a solution...
Sorry we seem to have gotten off topic. Simple answer big inverters need big battery banks which means a lot of weight.
2014 T@B CS Maxx
Martha Lake, WA
The 12V part is easy, as that just needs to be tapped into where the 12V from the battery comes into the converter.
The 120V part is what has me stumped. If you plug into the 120V plug on the inverter, that has to go the the breaker panel somewhere.
Any ideas?
Does anybody know if this type of install would be attainable with the stock unit in the T@B, minus the transfer switch and inverter?
I found this:
"The most elegant (and of course, most expensive) solution is to connect the RV inverter directly to RV’s AC distribution boxthrough a transfer switch (keep in mind the type of switch used varies based on the power of the RV inverter and if you have a generator). The switch will automatically select shore power if it is available, and inverter power if it is not. If you go this route, you still have to avoid powering the converter from the inverter. The most common method for achieving this is to use a split distribution panel, with the converter on the part of the panel that is not connected to the inverter. If that seems like a more complex RV inverter install than you want to try, read on for how to use a relay."
The thing I'm not sure you can do, is avoid powering the converter from the inverter...
There is also this image I found:
(formerly a 2013 T@B Q M@X); 2015 Jeep Sahara JKU (Max Tow)
Toronto ON Canada
Is your inverter box sealed from the elements? I noticed a fair amount of water gets into my tongue box when it rains.
Works great for charging all my toys - Let the solar get the battery fully charged in the morning and then mid-day with good sun I start up the inverter.
EWizard - By "tub" I just mean the standard propane cover. The inverter just sits in there on top of the coiled up dump hose. "Oh ick" you say - no, I keep the dump hose nice and clean. Gets dusty in there but the hose is clean :-)
