I was in B3 last night looking at blinds for a guest room, and yes, you can order blinds that go up from the base. Basically, they are accordion blinds that have a mounting on both the top and bottom, and cables to draw them upwards.PXLated said:
Personally, I like the arrangement the way it is. Have never seen shades go up from the bottom. They certainly don't in house windows.
I suppose if you were in the bunk and wanted to peek outside, a reversed blind would not be advantageous. Imagining Verna peeking out to watch her stuff blow away!
Nope, quite the opposite.PXLated said:They can still hear and smell - probably make them more nervous when they can't also see. Does me :-)
I have the same right angle ratcheting screwdriver that Dale has in his photo above. He's correct in that the black plastic knob on the back of the driver bumps into the back of the valance. Here is a right angle screwdriver I found on Amazon that doesn't have the knob - and should work without having to go to an open-ended wrench (Ugh! that must have taken forever - I can see how the bit would keep falling out of the screw hole with each attempted turn). So if this project is on your list, buy this little guy (no pun intended) and let us know how it works (only $9.99 on Amazon):
Were you serious? I couldn't tell. Anyway, I haven't done the mod myself but I like the idea of having the amount of opening decreasing from bottom up as it's adjusted rather than opposite.OutbackAZ said:My apologies. This mod is only applicable to guys.
This is why I have not switched it. I am still considering it.Mr_Mrs_Gnome said:I suppose if you were in the bunk and wanted to peek outside, a reversed blind would not be advantageous. Imagining Verna peeking out to watch her stuff blow away!
KyBawpaw said:Just bought that wrench! Free shipping with Prime cost me $9.96. Thanks OutbackAZ
Hum, I've never seen or heard that asked. I wonder...kccate said:With my dogs, who are calm if they cannot see out, I have to close the shades often. Would love to do bottom up with shades like nice pricy house blinds can do! Does anyone know if a flip can work with the 2007 Dutchman, where they both go the same direction, one inside the other?
