City Water Cap
On mine, it is open, then a little rubber flap. I broke the previous rubber flap, then went to a standard RV store and got a replacement. Not sure how the Little Guy city water is configured, but at any rate, it should be a standard RV replacement item.Carol
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL0 -
Ours wouldn't stay on either.
There are screw in replacements with tether. Google...Chan - near Buffalo NY
A_Little_T@b'll_Do_Ya0 -
Found one at Amazon, thanks! http://amzn.to/1RVEwR3
This has been one of those annoying things bugging me for a while but had not yet got around to dealing with it.
Mine gave up the ghost too, so I bought a threaded cap and that isn't going to pop off.2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)1
Cspur at Tabazona recommended putting a nickel in the cap to keep it on (I think). I removed the flip cap and replaced it with a hose plug from an RV shop. Wish I knew about the nickel trick.2016 Outback 320
Yes, I can never get the rubber cap to stay on either. I have also done what PXLated has done.
Sterling, VA0 -
Mine neither - I thought about putting a piece of plumbing tape on the inside to give it a snug fit but didn't have any when I was leaving a state park - so used black electrical tape (!) and so far it's holding.Michele, Tucson, AZ. TV - '13 F150 & '16 T@Bitha special order.
You never really travel alone. The world is full of friends waiting to get to know you!0 -
Modified blowout plug. (For some reason, second picture decided to flip over.) <- Corrected (Px)
2 -
Plastic blow upplughere, too. Larry, I need to use your chain retention cord idea. Thanks.Verna, Columbus, IN
Easiest mod/repair, to date.
Jenn - And that is/was? - The coin trick? - Can't tell by the pic.0
PXLated said:Jenn - And that is/was? - The coin trick? - Can't tell by the pic.
New cap - with better seal. This one has a lip that makes it a more snug fit.2021 T@b 320 Boondock "Mattie Ross" | 2021 T@b Nights: 239 | Total nights in a T@b 455 | 2022 Jeep Grand Cherokee L Overland | T@b owner since 2014
We tried the nickel in ours (Canadian nickel = 3.5 cents) It was too tight to fit, but strangely stretched the cap enough to make a new tight fit. This might be temporary, but the cap is holding for now.Mia Hamilton, Ontario, Canada. 2015 T@B U, formerly 2012 LG 5-Wide Platform1
Here is a photo of the inside, where you can see the lip.
I'm surprised they didn't switch over to the water fill/ city water hookup door like they did on the t@g's.
I lost a nickel!0
Longleafpine
Great discussion and ideas. Be careful if you are using any
type of rv cover as the water cap that protrudes will wear a hole in the cover in no time.0
