Thanks to all the great folks on this forum (especially Jenn's posts). When I got our T@B all I knew was we were over always having to tent camp and I was focused, as a builder in my past, on a floor plan that worked for our goals. The Q fit the bill and I was able to get one (2015) last Fall. So I focused on the layout and never knew anything about batteries and power, I had actually never stepped foot in a RV or trailer. Thank goodness the T@B spent the winter in a snow bank and I spent the time reading and studying. So with the snow melting and the ski areas closing we head out on our first big trip at the end of the month. There are no hook ups where we will be so I decided to augment our power with a Renogy 100 solar suitcase, 20 amp MPPT controller and install a battery cut off switch. The tires are almost melted out and it's ready to pull! Take a look. The battery is a 27 and we have two propane tanks. I riveted the controller inside the box so it would be out of the weather and the solar cords will use the Zamp port. The cut off switch fit in the battery case, so I mounted it on top. Tell me what you think.
Hey M Mike, I can not figure out how to make the pics smaller. You can delete if this is taking too much .....space. T
We are also reformed tent campers, and this will be our second season with the T@B. Last year, we still managed several days of dry camping, despite a failing group 24 battery and no method for recharging. I'm thinking this setup will be more than adequate, provided you are a little conservative with power usage.
Tory
I think you'll like that controller, looks like the same manufacturer as the one that came on our 2015 Roadtrek RV (yes, we still have our T@B, too). I've found that it will start charging (although not at full capacity) even before the sun hits it; it only has to be light out for that charger to begin its job. Apparently that MPPT technology really is an improvement.
We have 300W of panels on the roof, and those and the charger were all we had when the alternator charging system quit after cooking our coach batteries on a cross-country trip last summer. The solar system worked very well, at least during the day!
As far as large pics, check the menu on your camera to see if there's a choice of a smaller format; might be listed as an "email" format.
Have fun with your T@B!
Sterling, VA
