Anyone Towing with a 6 Cylinder Van? Into the Mts?
ADKersADKers Member Posts: 13
edited May 2016 in Trailer & Towing
We are about to embark on a trip out west (2000+ miles) headed to Glacier and were planning on towing with our 6 cylinder Sienna Van.  Are we crazy? This is rated for 3500 and so we thought we're ok, but some people (non-T@B owners) are saying we need a truck.   What has been your experience?
  • ddetarddetar Member Posts: 23
    I am using a Kia Sorento 6 cyl.  It has 275 HP and does fine.  We went into the mountains this weekend and had no trouble.  I used 3rd gear all the way up.
    We haven't towed through the mountains yet, but our RAM C/V (3600lb tow rating) tows our T@B very well. 5th gear on the interstates. Your vehicle will do fine, I don't think you need a truck. Plus in the van you have all that secured cargo  room, that's why I got mine.
    Does it have the towing package?
  • LibrarydragonLibrarydragon Member Posts: 103
    We have a V6 RAV4 with a towing capacity of 3500. We towed our T@B through the Sierra's and Rockies with no problems.
    Sara&Carl
    2015 max s outback, TV 2011 RAV4, V6, 4x4, & 2017 Tacoma Off-road 4x4
    Soquel, CA
    edited April 2016
    we have a 6 cyl Tacoma, 6500lbs towing capacity, and it's "OK" over our 10K passes...ya just gotta take it slow.  If we were in a hurry we'd take a plane...;-)
    J.D. & Sue
    2015 and newer Sienna's have the tow package by default, fwiw.
    T@@bulous
    2014 T@B CS Maxx
    Martha Lake, WA
    Ford escape 4 cyl with towing rating 3,500.  Has worked well in California mountains (not made it to Colorado or Utah yet.
  • longleafpinelongleafpine Member Posts: 12
    Longleafpine
    We tow with a 2011 Honda Odyssey and it does the job very well. I will add that we after market added the brake controller and transmission cooler. As with everyone else mileage while towing drops to 13 to 17 mph. We use the rear seat hanging rod as a closet and can carry anything we think we need. We have consolidated items with plastic bins.
  • leroybortleroybort Member Posts: 61
    We tow with a 2004 Odyssey and so far so good.  No real mountains yet, but lots of hills. We don't have anything special on it except what the dealer said we had to have - like lights.
    Sug@rsh@ck -  2016 Max S Outback, 2016 Nissan Pathfinder.
  • ADKersADKers Member Posts: 13
    Thanks everyone.  We ended up using our van and are half-way across the USA.  Everything is fine with the towing...except: We are having trouble with 30 amp fuses blowing. We've narrowed it down and believe it's due to a faulty wiring job of the installation of the 7 way after-market plug--or electric brakes.  Tomorrow's the appt to get it diagnosed.  If possible, use a car with factory installed towing harness.
  • dinzzydinzzy Member Posts: 182
    Our 2001 Honda Odyssey did not do well even though we added the biggest Trans oil cooler I could find.  The torque converter over heated.  I even have a temp gauge.  Early Honda Odyssey's have issues.  Our friend with your Seinna has had no trouble and he pulls a heavy tent trailer with a kitchen and bath.  Enjoy your time!
    edited May 2016
    Back from 6000+ trip and the Sienna was great!  -- No problems.  We downshifted over the Rockies and kept it in low gear, but that was all we had to do.  T@B tows like a dream.   We got an average of 15 MPG while we towed.  My van keeps track of that.
    My Wrangler crawled over Monarch Pass.
  • Sharon_is_SAMSharon_is_SAM Administrator Posts: 10,014
    ADKers- what was the issue with your 30 amp fuse?
    @SAM - It was the break controller.  The person who ran the break controller wire ran it too close to the muffler and it melted the wire, causing a short. After the nice hitch place troubleshot and fixed, we had NO issue.
    That happens more often than you know.  Good argument for the Prodigy RF model.  We will be towing with a Sienna as well.  Good to know it was smooth sailing.  What kind of highway speeds with the 15 MPG?
  • gulfareagulfarea Member Posts: 525
    mash2 My wife has a 4 cyl 2012 escape and it is only rated for 1,000 pounds towing, not 3,500. Are you sure yours is not the 6 cyl? Thanks Art
    2019 TaB 320 S Boondock Edge
    edited May 2016
    Art, the Ford escape with Ecoboost 2.0 engine with factory tow package is rated for 3,500 (at least with the 2014 model).  I was using a Forester (rated at 2,400) and the Ford definitely has significantly more power (HP and torque are both 250 as I recall).  The 1.6 engine is only rated for around 1,000 lbs.  Does your wife have a 2.0 ecoboost or just the straight 1.6 engine?
    And yes the 2.0 ecoboost is a 4 cylinder engine.
    The 2012 Escape was before the drastic body changes. The 6 cyl could tow 3500 lbs, but not the 4 cyl.
    mash, thanks for the reply and I wish we had the newer one Art
