We wanted to camp this weekend but Mother Nature is bringing a major snow storm instead.  In preparing I pulled that back shelf out to check the glycol level (it was fine).  Since I had it out I poked four 1" holes in it to let the heat out (there's a BIG radiator down there!). Because of some minor splintering of that nice Baltic birch ply, I made some oak "covers" for the holes (I'm REALLY jealous of Verna's craftsmanship...).
I noticed the floor level slot for "cool" air into the chamber...but it was mostly blocked by a rug we have under the table legs (to protect the floor)...whenever we're heating I'll have to be sure to pull it back.
                J.D. & Sue
There's a thread somewhere shows mine and then Verna went all fancy with scroll work and showed us all up.
J.D. & Sue
"Growing old is mandatory. Growing up is optional."
http://tab-rv.vanillaforums.com/discussion/518/rear-panel-heat-slots/p1
http://tab-rv.vanillaforums.com/discussion/comment/31584/#Comment_31584
J.D. & Sue
Central,Fl
2015 T@B Max-S
J.D. & Sue
look at were floor meets vertical board notice notch out. This is not my unit just borrowed pic for reference
Central,Fl
2015 T@B Max-S
J.D. & Sue
I look next day or so believe so is make up air not 100%
Central,Fl
2015 T@B Max-S
J.D. & Sue
J.D. & Sue
J.D. & Sue
Thought you had a vertical back rather than the slopped.
J.D. & Sue
I have a memory foam mattress that is 3" that covers the entire bed. That was enough to sleep on the Alde-cushion side and not get warm on bottom and cold on top.
I have put the memory foam crossways in the back bench (folded over) and it's a bit too much (thickness-wise). I've been experimenting with different sleeping directions (I'm only 5'6"). Heavy and unwieldy. I've got a 3" thermarest on order.
http://ventmastersstore.com/collections/small-round-vents
2016 Silver/Black T@B M@x S with Scuba Black interior. 2015 Lincoln MKC AWD 2.0L Ecoboost tow vehicle. Tekonsha Prodigy wireless Brake Controller.
http://ventmastersstore.com/collections/small-round-vents/products/1-5-round-open-screen-vent-black
i plan to counter sink to be a flush fit...
Much cleaner look and more functional
Central,Fl
2015 T@B Max-S
