On my first trip of the year with 2014 CS-S, i was unable to light the stove. It would briefly light when pushing the ignition knob but once release there was no gas flow. I then turned the Alde to gas and had a solid red light on the analog panel. Tank was full and tried a 2nd tank when I returned home with the same result. Inspected all the propane hoses and everything looks good and there are no leaks at any of the fittings. Seems like it has to be the regulator - does anyone have any other suggestion?
Bryan & Vicki 2014 T@B CS-S MaXX ** 2016 Chevy Silverado Double Cab
Transplanted Hoosier in Richmond, VA
Go Colts!
0 ·
I got a bad exchange tank last summer. While full, it wouldn't put any out. Same symptoms as yours (Alde red light, etc)
Go Colts!
If you can find a Norcold dealer/repair business, they would be able to tell you. I'm making an assumption your warranty has run out.
Go Colts!
Go Colts!
PXL, a nanometer is about 25 millionths of an inch. I'm sure yours is right there in your T@B, you just can't see it.
http://www.rvdoctor.com/2001/01/avoiding-pitfalls-of-rv-propane-system.html
If only at night I expect ten to fourteen depending on how much cooking I'm doing.
That low end seven days is where the Alde is running a lot.
hopefully replacing it with Fairview GR-9930 as stated above messages will be easy to do and fix
