Dripping Noise
We took our 2015 Tab out for the first time last week and were hearing quite loud dripping noise from behind the AC/Bathroom side wall whenever the Alde radiant heat turned on; is this normal?
  • Nomad
    Nomad Member Posts: 7,209
    What model of T@B do you have?
    Sure it isn't the gurgling of the Alde fluid in the reservoir tank? Might want to check that it isn't over flowing.
    My tank is in the rear but some models have it more forward as I recall.
  • Juslou
    Juslou Member Posts: 9
    Actually it's a 2016 so has the digital Alde panel, possibly still same issue?
  • Nomad
    Well, the Max-S would have the resevoir in the back. There's an long vert access panel by the drivers side bench that's not hard to remove - Could take a look in there and see if the shower plumbing happens to be leaking. Even though you say it's only when Alde is running.
  • Juslou
    Thanks all, I will check out the pump speed. Glad in a way to hear that this is not normal, would make owning a Tab not as great. On the other hand I'm bummed to hear it already has an issue.
  • Juslou
    Here is a link to video of the reservoir which us making the noise:
    https://www.dropbox.com/s/44v7mphw8ib0n8j/2016-05-08 17.46.56.mov?dl=0
    Note that no fluid is actually flowing from/to the reservoir; should there be?
    Does the fluid level look too high?
    I changed the pump setting on Alde control panel from '2' to a '1' but no effect.
    It's loud enough to keep us awake so hoping to resolve it.
  • Nomad
    That gurgling just sounds normal to me.
    I noticed it when I first got the T@B but after a short period, the brain declared it background noise and filtered it from my consciousness like most other ordinary sounds.
  • Tabaz
    Tabaz Member Posts: 2,421
    This is a common issue with the Alde.  To quite the gurgling sound, add more fluid to the reseviour. It makes more noise when the fluid is at the "minimum" mark. If still too noisy, then lower the pump speed. There are a TON of threads on this topic.  Too bad the search function is weak.
  • jkjenn
    jkjenn Member Posts: 6,423
    edited May 2016
    Mine must have done that, as well.
  • Verna
    Verna Member Posts: 6,876
    After 3 months in the T@B every night and day....what gurgling?
  • Nomad
    Amazing how the brain saves our sanity.
    Can you imagine if you were conscious of every single thing you heard, saw, smelled, touched - would all be inane. Thank god for subconscious filtering.
  • Nomad
    I've suggested this in other threads - get some sound dampening insulation and wrap the tank.
  • Verna
    I have two friends, married, who both wear earplugs to bed every night. They both snore and with the earplugs they are no longer grouchy when they get up in the morning. Sometimes, if you can't get past the noise, you have to make changes to put up with the noise. The Alde is a great furnace, as opposed to no furnace last winter in my teardrop when wintering in AZ.
  • Nomad
    And that gurgle is a lot quieter than a furnace fan.
  • Ratkity
    Ratkity Member Posts: 3,770
    Welcome to my world of jack-up senses. While I can normally filter out constant noises, there are certain frequencies that play havoc with me and start migraines. Same with lighting. I deal as best as I can with resources available for me. I have a white noise machine that works on batteries that has been a life-saver for sleep. It even drowns out the snoring old cat and dog (but not me ;) ). Don't even start me on taste, texture and smell. Avoidance is mah middle name!
  • Nomad
    So the white noise machine works? Would it work for filtering out a snoring partner - My sister inlaw wants to know. They're thinking of a camper but my brother may still have to tent it if there's no solution :-)
  • Ratkity
    There's a volume control on my noise machine. Depends how loud said H snores. My Dad can shake windows when he snores. Light to medium snoring that is not pressed up against SIL ear? I'd say it would work on the "waterfall" noise setting. It sounds like a box fan noise. Avoid the noise machines that mimic birds and such. When the power goes out, mine defaults to birds. One morning, I swear I was going to make those stupid chirping birds pay outside my window at 5 am until I sleepily realized my noise machine was the source. lol. Birds were free to chirp later that day.
  • jkjenn
    My three brothers snore unbelievably loudly. You can hear my one brother two floors below, with doors closed! Another brother would wake his children, who were sound asleep in their rooms.
  • Ratkity
    I'd move into the T@B... down the street.... in another neighborhood LOL.
