Got a battery switch, and before I get my new battery (yep did the first one in less than 3 months), I want to install the switch in the battery tongue box. So my husband was asking me if he should install it on the positive or negative line from the trailer. I said I thought it should be on the negative line, but when he asked me why, I really couldn't give him a logical answer. So I have come to the experts. I have looked in the forum, but I haven't found anything.
T@BOO - 2016 Outback Max S in New Mexico towed by 2016 Toyota Highlander (soon)
0 ·
It's one of those topics that doesn't resolve into a firm answer. The general concensus (I think) is on the positive - the cutoff switches are red after all. BUT, there are many that insist it's the negative.
I personally would do the pos.
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
If you are going to muck around with the positive terminal of your battery, make sure the negative terminal is disconnected first.
If you don't do this, and you accidentally "bridge" the positive terminal to some grounded piece of metal on the trailer, you will enjoy an impressive fireworks display, followed by a change of underwear. Damage to equipment and persons may also result.
So, if you are removing a battery, always disconnect the negative first (and reconnect it last). If you are using a cutoff method that requires exposing and accessing the battery directly, then I would switch off the negative post. Any time you are working near exposed battery terminals, you would do well to disconnect the negative cable.
If you are using a sealed switch removed from the battery--and the battery will remain enclosed in its plastic box--there is virtually no possibility of bridging. Put the switch wherever you want and camp on!
