and I am not quite sure about the finished product. I used an Extreme Max Bolt On Spare Tire Carrier and two 2.5 inch muffler clamps. Due to the width of the clamp there is minimal contact of the clamp to the jack. Also I only tightened it enough to flatten the lock washers because I did not want to dent the jack tube. Did I miss something? Should I wrap the tube in some type of rubber to fill in the gap and get more purchase for the muffler clamp?
Pics, please, when you're done.ChanW said:I'm in the process of installing mine on the tongue. I was going to wrap the crank tube with a heavy pipe (split in half lengthwise), to spread the pressure of the u-bolt, and try to prevent denting or damaging the tube.
I have my tire sitting on some angle-iron cross bars that go across the tongue for support.
Photomom said:Pics, please, when you're done.ChanW said:I'm in the process of installing mine on the tongue. I was going to wrap the crank tube with a heavy pipe (split in half lengthwise), to spread the pressure of the u-bolt, and try to prevent denting or damaging the tube.
The mount can be easily removed by loosening the two nuts holding it in place. (Much easier than getting the tire itself off, I might add...) The heads of the bolts themselves are not accessible, so I just left them in place and put the nuts back on. I may have even included a rubber washer--can't remember.lapowers57 said:Once the spare tire is on the tongue can the factory spare mount under the trailer be removed? I was thinking of removing it and then putting the bolts back with rubber washers to protect the holes from water infiltration. What have others done?
Don't know about that, but the trailer shop where we had our brakes adjusted had a T@B owner come in to get the spare mounted on the tongue.jbug10 said:Where would I take my Tab to get my spare tire moved to the tongue and remove the bolts underneath? Any regular RV service center???
I travel on some pretty rough roads getting to rivers and bottom out with the spare tire once in awhile. The clearance is very low when the tire is underneath.
