I have the bargain priced Tekonsha Voyager 9030 proportional brake controller:
The controller is properly mounted and carefully adjusted per the user's manual.
Last season, I noticed the brakes had a tendency to lock up. This would happen suddenly, while applying the brakes, just as the vehicle was about to come to a stop. It seemed to happen most frequently when stopping on a slight downhill incline. However, it did
not happen consistently. Routine adjustment of the brake shoes seemed to have no effect.
I could prevent the problem by letting up a bit on the brake just before the stop, or by dialing the controller level
way back. Workable but imperfect solutions.
Anybody have any experience with this controller, or with this particular problem? If so, any insights? Thanks!
Condo A-Go-Go
2017 Tacoma (AH GOGO)
S. UTAH
Technical Assistance Call Toll-Free: 1-888-785-5832 or www.tekonsha.com
The AL-KO axle manual includes both an improperly set/defective controller and "brakes under adjusted" (whatever that means) as possible causes for grabbing.
Mike, thanks for the Etrailer link. It seems plausible that the mechanical innards of the older tech Voyager could play a role, particularly where the grabbing occurs intermittently, only under certain stopping conditions, and that dialing back on the level control mitigates the problem. Barring an upgrade to a fancier controller, it may be one of those things that just requires on-the-fly fine tuning for different conditions.
Of course, even if the controller mechanics are the culprit, I'm sure brake adjustment and condition also factor in.
I'll keep twiddling with it once the T@b is out of mothballs. Thanks for all your input--be sure to update if you learn anything new!
Bottom line, I thought I had a long delay to relatively low power with a setting of 9.5 / 20, but really that was a long delay (20) to 95% of max power.
(This should give you folks an idea of how much weight you give to any other advice I may provide on this forum...)
- gcw
At least none that I talked to in Parker, Lake Havasu City, Bullhead City & Kingman - That's why I uprouted and headed to Vegas. Even in Vegas, Las Vegas Trailer was the only one that was knowledgable. You'd think with all the campers, boat trailers and construction trailers out there there'd be more.
Sahara RV was somewhat knowledgable but didn't stock parts. UHaul with all their trailers didn't mess with electrics. CampingWorld was a no go.
Condo A-Go-Go
S. UTAH
Durango, CO
2015 S Outback
Condo A-Go-Go
S. UTAH
