Where is the valve that will keep water from pouring out of the drain pipe that extends down behind one of the water tanks? It's about a foot from the side of the Tab opposite the door and behind the tire. I believe that I have the Alde hot and cold water drains closed and the freshwater tank drain. What's left? The new Tab was winterized by the dealer, so I don't know what they did to open the system up when draining the water (or what I need to do to close it). I won't be filling the Tab with water until I figure out what's open.
                0 ·
2022 Ford F350 Tremor | 2022 Cirrus 620
Note that in the photo above, the drain is closed (which is the position you want it in for normal operation). To open it, you flip the little yellow lever up so it is perpendicular to the pipe.
