Apparently I need to acquire a torque wrench for my lug nuts. As I have no experience whatsoever with this, would someone please recommend a specific one that is appropriate and not too costly?
0 ·
Curious - How many that do own one do carry it on the road.
Now, it's a fact that I'm a minimalist and carry as little as possible but I still carry way to much and need to cut back. Still trying to get to that stage of carrying only stuff I use on a regular basis.
Take your middle finger tip, touch your thumb tip to make a circle. That's about how big around it is in the package. 14" to 18" long. Put it in the passenger seat tucked between the seat and the back of the seat. Then you have to remember where it is!
My decision is... First, is it absolutely necessary. Otherwise, will I use this on a regular basis enough to justify the added volume. And/or is there an alternative. And/or, can I get it on the road if it turns out to be essential. And/or, can I get it as a service.
For instance, I'm going to get my tires rotated on a regular basis - The tire shop will have a tourque wrench. On the other hand, a tire iron is essential.
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
Do you need it? I don't know. I have two torque wrenches I use for delicate or critical fasteners on my motorcycles. Lug nuts I just tighten by feel, which comes with experience. FWIW, I don't have great faith that tire places always torque to spec--I've had lug nuts that were near impossible to loosen by hand, and even broken lugs. Torquing fasteners to proper spec ensures a snug fit without risking damage from over-tightening.
90 lbs is what I was told
2016 NuCamp 320 T@B Max S
T@bbey Road
Appleton, WI
MOUSE-KE-T@B
Harvest, AL
90 inch-pounds would probably leave your tires a little wobbly!
Getting back to the original question... A properly-sized beam-type torque wrench (see photo) will probably be the most economical option. They're not as convenient to use as a ratcheting clicker-type, but should work just fine for getting your lug nuts close to spec.
I bought a used high quality torque wrench then had it calibrated. Note: I wrench on my own cars so having a good one was critical. I have the kind that clicks when the proper torque is achieved. I did not go with digital as I did not want to worry about batteries - especially after it sits for a while.
Whatever you do, protect it by keeping it in its case. If you drop it the calibration can go out of range.
As ScottG stated, after a while you will get a feel for how much torque you are applying. However, I always torque my lug nuts to proper specs.
Durango, CO
2015 S Outback
You'll need an extension to go with it, to reach in, to the hub.
Really good place to buy all your needs. They also make a folding lug wrench which [YEAH I KNOW PXL!] takes up very little room!
South Carolina
Tire places and auto repair shops, in the never-ending effort to speed things up, most often use a "torque stick"; the idea is that the "stick," rather like a ratchet extension, will flex when it reaches the proper torque rather than apply the torque to the bolt head or nut… but then, since everyone likes to avoid lawsuits, techs will sit there and let the impact wrench hammer on for several seconds after the stick ceases to turn and "twists" (having reached its value), just to "make sure" the nut or bolt is tight.
Couple that with the --and I've seen this-- up to 20% deviation from specified torque value that torque sticks are designed for, and you have the result that if you have a flat and need to change that tire you could be in a real pickle.
As a result, ANY time anyone else touches my wheels, the first thing I do when I get home is break the lug nuts loose and re-torque them correctly using my torque wrench. Without exception.
The original owner of our T@B bought a torque wrench and it resides under the rear bench seat with the spare (older Dutchmen model), but I can't say that I've ever used it. I leave it there "just in case," however. Do you NEED it? Probably not, if you can verify that the lug nuts were properly torqued to begin with. I just never trust anyone else on this, but then again, I can get pretty anal about "my machines," from 40+ year-old motorcycles to brand-new vehicles, to a 60-year-old airplane.
So if you always have AAA or something like that available, and never are in a "far-off-the-beaten-path in the middle of nowhere" place, no problem. Personally, I will never take a long trip without my toolbox, and I would still recommend to anyone that they verify that lug nuts are/were properly torqued.
I have watched auto techs do exactly what @ScottGdescribed. Matter of fact, one used only a compressor impact wrench and it wasn't set to turn. As a result, the wheel almost fell off (I was a teenager and wasn't paying attention to the fact the wrench wasn't turning). A good citizen told me to pull over after a mile. Didn't lose lugs or bolts, but was a bit shook up.
I've had to stand on a crossbar lug wrench because the lugs were on so tight. Thanks @ScottG! Changing a tire is hard enough on the road. Fighting with lug nuts that are over tightened just adds insult to injury in a frustrating situation. It never occurred to me to re-torque all wheel lugs and keep a wrench in the vehicle. Simple solution! Thanks again
2019 Ford F-150 3.5L Ecoboost with Long Bed
