So, does anyone know how high we should allow the tire pressure to become while hot? We plan on driving to the hottest place on Earth (Death Valley) and the to high country where it might freeze. It's OK to call me crazy but I'd still like any advise about this.
The factory hasn't completed their investigation for the final answer. Me, if you have the original tires, go by the sticker, but I still go by what my tires tell me. If I'm going to be in extreme hot tempos, I would drive some, get the tires up to driving temps, check the tires again. If they are over what they should be, let some air out. If under inflated, add air. The only way you'll know is by checking. Do you have the same sticker on your tongue as shown above?
Verna, Columbus, IN 2021 T@B 320S Boondock “The T@B” Towed by a white 2019 Ford F-150 4x4 Supercab, 3.5L V6 Ecoboost “The Truck”
To the best of my knowledge, tire pressures are always indicated as "cold" (i.e., not being driven). The pressure will increase a bit as they heat up from driving, but that is accounted for in the recommendation.
That said, your "cold" tire pressure will fluctuate depending on ambient temperature. If you are moving between extreme climates, I would check them again (cold) and adjust the pressure as needed.
And, if you do that, you are probably 10 steps ahead of nearly everyone else on the planet, so pat yourself on the back!
Not sure if this was directed at me, but yes my trailer has the ST tires from the factory and also has the "50psi" sticker....
Personally, in the year + that we have had our T@B, I've kept the tires between the owner's manual 35psi (actually never on the low end ---which sounds very low) and below the 50psi listed on the tongue and tire itself. Likewise, I am one of those goofy checklist guys that checks the tires on the TV and the T@B at every gas stop with a toe tapping thump (or an air gauge if it looks suspect). I also at each stop, touch test both tires and the hubs for temp....
Proper inflation would help gas mileage a bit, and extend tire life I think. The T@B is so light, and as others (including the owner's manual) have said a little less air pressure may help the ride quality. It should not be so difficult to find out what air pressure Pleasant Valley puts in the trailers when they leave the factory as a baseline number....I'd like to keep mine at factory specs.
And if Pleasant Valley needs a technical writer to create a relevant owners manual, my wife and I are up to the task. Are they hiring?
Oh, and thank you Verna! I truly appreciate everything you do on this/these forums to keep things running smoothly, and for sharing your experience. You are an awesome ambassador! PS~~~> thanks PXLated too.
Ditto!
Ahh, shucks . Thanks, Catndahats and Photomom. But don't forget PXLated. He sure spends a lot of time here helping.
I'm not here a lot because I'm trying to downsize at home (too much stuff for one person after living in this house for 25 years), and I'm finishing my Verna-do list so I can put my house up for sale. No, not full-timing, but downsizing from a 1/2 acre plus 1800 sq ft to about a 1,000 sq ft condo with no yard work. That will mean more time to woodwork and camp! I'm on a first name basis with the Goodwill drop-off guys!
I would LOVE to get a patio home or condo and get rid of the yard..... Will you be able to get a condo with an 8ft garage door? That's our challenge. We did find a patio home community that could put an 8ft door on the back garage, BUT those things are more expensive than a house twice the size with a 1/2 acre lot.
The T@B will have to go to an outside storage lot, unless I can find that farmer who uses his barn for RV storage. I have to accept it, although it was a difficult decision. My T@B is outside at my home, so it won't be much different, except I'll be visiting her frequently. My truck has never been in my garage.
I already know which complex I will be living in. The single story 1,000 sq ft condos have a long 1 car garage and that is where my woodworking shop will be. I do have my priorities. I would give up the spare bedroom and 2nd bath if that meant I could park my truck inside!
In my area patio homes are targeted at well to do baby boomers and young retirees who are downsizing. They generally have luxury kitchens and every amenity but are smaller versions of the upscale homes the target demographic is moving from.
Thanks for all of the comments and good wishes. We were indeed lucky. T@B is an 08, so tires probably 8 years old. The tire brand is MERIT MYSTIC. Sits more than rolls, so we should have thought about new tires sooner.
Yup, that's the case here. We are moving some time this year. We thought for a few minutes we might like no yard work, but the higher price turned us off. With the same builder, but different location, we can get the "exact" house we want with 5 cars worth of garage (3 attached, two detached with 8 ft. doors), lower price, lower taxes, lower HOA, and still pay somebody to do the yard if needed instead of the patio home.
Merit Mystics are definitely original tires. I've changed mine out twice. Kelly tires are my replacement. Less than $200 every 4 years.
Thanks, I stand by my earlier comments as it's like anything else, you have to figure some things out on your own and take action in maintaining things properly and that is something I've tried to always do whether it is my personal vehicle, trailer bearings, lawn equipment, etc.
With that said I did send a follow-up "reminder" message to the factory this afternoon and asked them for further clarification/recommendations and guidance on the tire air pressure issue so that everyone gets it from the horse's mouth if you will.
Stay tuned!
I'll be interested in their advice, because I've read from a couple of sources, tire mfgrs and that rubber association, that ST trailer tires are always supposed to be inflated to their maximum.
Chan - near Buffalo NY 2014 S Maxx 2011 Tacoma 4cyl ... edit: 2022 Tacoma 6cyl - oh yeah! A_Little_T@b'll_Do_Ya
I received this back from Scott Hubble this afternoon. And keep in mind too that they are working on an updated manual and hopefully will clear this up via new verbiage when it comes out:
Without forming a statement that sounds professional and fancy, I can tell you that in my discussions with the appropriate individuals and entities, "we recommend that every trailer produced by Pleasant Valley trailers have the psi in the tires match with what is imprinted on the tire itself."
I know trailers are different than vehicles, but on a my friend's 2004 Dodge diesel dually pickup, I contacted Firestone about her two new front tires and they asked "what vehicle are they on?" when I told them the tire model number. After I told them the vehicle, the help person gave me what exactly was on the inside of the vehicle door after he asked if there were any hub or front end mods first (none). He said tire pressure (qualified here: on a motorized vehicle) is dependant on vehicle weight, type, if front or rear tires, and finally, manufacturer recommendations for best handling. The recommended rating for her front tires were 65 lbs and max rating on these tires were 80 psi, btw. The last thing the Firestone help dude said was to never run a tire at it's max rating (still discussing motor vehicles).
Due to the above conversation, I'm still dubious about "running at max", especially with a light-weight trailer (due to bounce and handling for a small TV).
That said, I can tell you that most motorcycle accidents occur due to under-inflation of tires. All the Harley's I've owned have had specific tire pressures for each bike despite the "max" tire pressure written on the tire (motor vehicle again). Each salesperson I've bought a bike from has always given me a specific sheet with large numbers on a motorcycle picture telling me front and rear tire pressure for the bike - circled and re-iterated (CYI and safety issue).
So color me confused at the tire pressure on the different type trailers now!!!
I agree with Ratkity--automobiles and motorcycles will have a recommended inflation pressure (indicated on a sticker) presumably based on a number of factors related to the specific vehicle. The manufacturer of a non-OEM replacement tire might have a different recommendation, but in every case I've seen it's always below the MAXIMUM pressure indicated on the tire itself.
However, it does appear that trailer tires play by a different set of rules.
On a related note, I noticed yesterday yet another T@B sticker providing tire information. This one is on the lower front driver's side of the camper body itself. I am pleased (and relieved) to report that it contains the same information as the sticker on the tongue. Phew!
The sticker also has your VIN running vertically on the right hand side. Came in handy when being inspected CHP as part of the registration process in CA.
Seabrook, TX
2014 T@B Q Max, 2012 Toyota Tundra 4.6
Seabrook, TX
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
MOUSE-KE-T@B
Harvest, AL
MOUSE-KE-T@B
Harvest, AL
Great post, and one all should heed!
Stay tuned!
One of those days :-(
