PXLated said:Only time I've ever had an oder was after a dump
ROFL. Sorry, dirty mind. ;-))
Judy, I pull the lever for about the count of two normal flushes....if you can figure that out. The black water tank lasts me for 7 or 8 days, one person.Justjudy said:How much water does it take to cover the bottom of the black tank? I have read that the bottom should be completely covered by water before the treatment is added. I don't want to put in TOO much water, since the tank capacity is only 6 gallons.
I would think if you purchased a gray water cap with a hose adapter built into it, you could stop the flow enough to be neat about draining just a bucket full of gray water. The gray water comes out of the "chute" so quickly that it would be hard to contain without an adapter.Photomom said:Would it be possible to dump the gray water into a bucket and use that for flushing?
How about something like this?
Yes, that is what I was trying to describe. I bought a shut off for the end of the hose (probably should put it on this attachment) so it can instantly be shut off. My gray tank fills up quicker than the black, so if I use the gray for flushing, that will save me a day or so between dumps. Walmart has 5' black hoses so you can keep your hose uses separate.Mr_Mrs_Gnome said:How about something like this?
J.D. & Sue
