Where to buy 125v 4a Glass Fuse?
jkjenn
jkjenn Member Posts: 6,425
I blew the fuse in my Fantastic Fan and warmer temps are coming this weekend. Would I be better to start with a True Value Hardware, an auto parts store, Tractor Supply, or skip those and go straight to an RV place?
FWIW, I had to use the magnifying app on my phone to see that it was blown.
  • Nomad
    Nomad Member Posts: 7,209
    Did't know it had a seperate one - where is it?
  • jkjenn
    edited June 2016
    There is a little black cap you can see on the fan, itself. It is inside of it, at least it is on my 7350 upgrade. I think the old kit had it, too.
  • Verna
    Verna Member Posts: 6,876
    Auto Parts store, Jenn. Do you know why the fuse blew? It helps to know why before replacing.
  • Photomom
    Photomom Member Posts: 2,217
    Some Home Depots may have them. You need to know if it is fast blow or slow blow. What other markings are on the fuse?
  • Mr_Mrs_Gnome
    Mr_Mrs_Gnome Member Posts: 241
    @jkjenn, I just called them. It's a 4amp (voltage doesn't matter) slow-blow fuse. You can get them at most auto stores.
  • jkjenn
    edited June 2016
    Yes, it happened when I was reversing fan air flow.
    Thanks, none close to me. It's a slow burn fuse.
  • jkjenn
    edited June 2016
    Thank you!!!
    The good news is that I often get fan action just from the wind swirling it around.
  • Mr_Mrs_Gnome
    Did you happen to call the Twin Lakes store (just in case)? I can probably mail one to them for you. Not sure how long Priority Mail would take. It's that or LV or BV.
  • Photomom
    An electronics parts store would have them if there is one near you.
  • jkjenn
    edited June 2016
    I will definitely check them out. Such a great little store!
    None close.
  • Ratkity
    Ratkity Member Posts: 3,770
    edited June 2016
    Um, an unsafe way to circumvent the fuse is to take some heavy duty aluminum foil and roll it up to fit the fuse holder. Not advocating this, but heard about some of my kinfolk that may or may not have done this as a temporary fix (and lived to tell about it).
  • jkjenn
    TL had up to 3a but nothing higher. They really have a little bit of everything there. True Value was the first stop on the way into BV and they had what I needed.
    Doing laundry now but will pop one of these in when I get back and hopefully we are back in business.
  • Mr_Mrs_Gnome
    @jkjenn, sorry you had to drive that far. At least you killed two birds. You should buy an extra 1 or 2 4amp fuses and leave them with Katie & Carl at TL as a small token of their coolness. They were so good to me when I hiked through there. Katie really needed a lift when I called her today. I'm going to have to bring some kind of treat to them from the "big city" next time I'm there.
  • jkjenn
    Good idea. Not a big deal, only about a 20 min drive and I needed to do laundry and am now catching the Cavs game at a local restaurant.
  • Vikings
    Vikings Member Posts: 147
    Radioshack has lots of unusual fuses...including the ALDE 3.15/250V fuses under cover on top of ALDE boiler.
    Kim & Mary Kay,  2016 CS-S,  Spokane, WA
    Map of Provinces I Visited
  • ChanW
    ChanW Member Posts: 3,165
    I looked at our Radio Shack for that Alde 3.15A fuse, and all I could find there was the slow-blow version. The one that came out of our Alde was a fast-acting fuse.
  • jkjenn
    I have some of the Alde fuses, ordered from Amazon. Smaller hardware and auto parts store are more accessible where I am than big box stores or electronics stores. The local (30 min drive) True Value is quite a store, however. They carry some camping, hunting, fishing, and boating supplies and do propane refills.
  • ChanW
    I love real hardware stores.
  • Nomad
    I roamed one today :-)
  • Nomad
    boo - That's a problem when traveling. Many areas don't have.
  • leenscottfl
    leenscottfl Member Posts: 254
    I have found that boat supply outlets have hard to find items items needed on an rv. After all a boat is just a floating rv. But I'm from Florida where boat stores are everywhere.
