After our last camping trip I went to drain the freshwater tank only to find that the valve handle under the stairs was missing. It looks like it just came loose and fell off rather than being broken off by force. Has this happened to anyone else? If so, how did you find a replacement? I am not able to find them anywhere.
                0 ·
Worst case, if you can undo and redo a PEX compression fitting, you could just replace the entire valve with one of your own choosing.
PXL, if you've lost two handles, you must have replaced one. Where did you find it?
Since, realistically, I probably won't check mine, I'll just plan on losing it at some point and hunting for that replacement. :-)
