deputydog
Member Posts: 103
Un-winterizing T@B to go camping, I hooked up fresh water line to T@B attachment for fresh water. get constant stream of water from rear of trailer drivers side, from some type of draining tube? with pressure on, ex. camping hose continues to feed water. This has never occurred before, so I'm thinking I must have turned a valve near furnace, but do not recall doing so? Need suggestions for this Old School newer camper.
TV is a 2007 Jeep Liberty. Own 2015 T@B Maxx s/wet-bath white green. St. Clair Shores, MI.
Can't get at mine at the moment to tell which one but should be easy to find.
The hot and cold water drains should be pretty obvious. The Alde hot water drain PXL describes is in the blue water line leading into the bottom of the Alde. It has a yellow flap-thingy on top. If the flap is sticking straight up (perpendicular to the pipe), the valve is open. Close the valve by pushing the flap down flat (parallel to the pipe).
ScottG. Followed your suggestion and yellow valve was down, closed. Thanks Maybe I'll call Factory?
Beyond that, my only other guess is a malfunctioning valve. Again, I would guess the Alde drain before the hot and cold water drains. Did you try flipping the yellow lever up and over a few times, just in case something was sticking?
Can you could get a bead on exactly where the water is coming out? A photo would be helpful, if possible.
A photo of those three valves would be good, too. The ones in our Tab are different from the newer ones.
