Well, I pulled our T@B out of storage last Saturday, and (( ! ))   The repairs I had made last year to the soft floor seem to have worked out very well, to the point that the floor now feels rock solid compared to before.
To repeat what I had done:
1) Reinforced the center section of the floor with expanded aluminum grating, supported by U-shaped steel beams across the frame from below
2) Added 1/4" steel plate to the worst area(s), near the entry door and under the below-cabinet storage area on the front right side (attached to frame)
3) Lifted the vinyl flooring and applied (saturated, more like it) a product called Rot Doctor, a 2-part cellulose-based epoxy, to the softest areas in the plywood floor (see above).
This was all due to the problem of moisture infiltration as mentioned by several others in this forum; take note and inspect those seals, people!
However, I have to push that Rot Doctor stuff: as wood is cellulose, and most 2-part epoxies are polymer-based, Rot Doctor stuff stands alone in being cellulose-based. It REALLY bonds to the wood. No, I'm not an employee, nor have any connection to the company, but am always looking for viable solutions to vexing problems.
That stuff really works, period. It takes a few days to fully cure, but when it's done curing it makes soft wood rock hard, and is "watery" enough that it penetrates extremely well on application. I plan on using it for a number of other projects where I have a water-induced wood rot, softening, or a just plain weathering issue. The T@B?  Our Boat?  Exposed exterior window sills?  The list goes on & on!
I was just really happy to step into our "vintage" T@B and feel the solidity in the floor!   OK,  rant (?) over….
                2 ·
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
MOUSE-KE-T@B
Harvest, AL
Not sure how well they show, but I took some pics.
Already replaced all hardware inside the battery/propane "tub" with stainless when I had that off last year, and replace any steel hardware with ss on anything I disassemble as I work on the T@B.
Reminds me of my boat… some of its hardware didn't last through the first year; it's now 30 yrs old & still going. (I mean really! Plain steel staples on seat upholstery?!?) Bean counters….
I have a 2012 T@B as well, and have had the same problem right off the bat. Pleasant valley did reinforce the flooring of my T@B with extra angle iron below, but that only partially solved the problem. Since then I have installed some laminate flooring which seems to distribute the weight better and the problem is not nearly as noticeable.
While moisture can cause this problem, it seemed to mostly be a problem with the flooring material itself in the first few years Pleasant Valley was building them. It took them a while to solve it, but I think they have now.
Sterling, VA
Alternately, do you have pictures of the reinforcements you've done? I'm intrigued by the aluminum grating and steel beams you mention as our problem is one of sag on either side. Do yo have pictures of it? I think we're solid on the leading edge as last year I had our service center install diamond plating which wrapped underneath the front edge since I noticed that the front underside was showing some road rash.
Ours is water tight but somehow we get dust/fine dirt sneaking in over long trips. Is the re-sealing of the wall to floor along the front or on the sides as well? Do you do it all along the outside? You also mention sealing along the black fender wells and floor. Did you get stuff coming in through there? Do you have gaps along the top of the fender and the body? I found expanding weatherstrip that seems to have filled that gap for us well and on the outside I used weatherproof foil tape to make sure nothing comes through or catches.
Great post irvingj....I would be very grateful to see pictures of your the support work you did underneath. What did it cost for your shop to do this?
And yes, we did sell ours, but unfortunately it had some additional issues about a year after. As I understand it, my repairs apparently held up -- the floor remained solid -- but the whole camper lifted & pulled loose from the frame when the new owner was forced into a rather sharp turn at relatively high speed; not sure what his plans are beyond that.
Take-away: probably best to do it right and replace the whole floor like Geo did.
This Weekend's Project-Laminate Floor Installation
I'd also be happy to send --via email-- additional pics of my repairs to anyone who'd like to see them, but I still think replacing the floor would have been (would be) the better way to go. stubby57a@gmail.com
Walt
