We have been discussing whether we need to buy a generator or the Zamp solar panel for our 2016 T@b. We would love to hear your opinions and experiences before we buy. Any thoughts please? Also, what watt solar panel would you recommend? Thanks!!!
0 ·
Much depends on what you want to run, and for how long. If you don't want to rely on guessing, then buckle in and follow Verna's advice!
Thought I'd use the gen more but don't.
1) We treat the T@B more like a nice tent (ok, a really nice tent...) We've yet to use the A/C, and don't have a need to run any other dedicated 120V appliances.
2) To be effective as a battery charger, I would likely need to run the generator for several hours.
3) I didn't want to carry a generator, or the gas to run it.
4) I'm selectively frugal and a bit lazy. Generators are more expensive--and require more maintenance--than solar panels.
I also gathered input from across the spectrum. On one extreme, jkjenn's comprehensive power consumption spreadsheets gave me a bead on how much juice I needed. On the other end, PXL's real world experience full-timing with a 120 watt panel and a basic battery convinced me it didn't have to be complicated.
As I implied before, the first thing you need to do is figure out your particular needs. If you are new to camping, or even just new to the T@B, this can be a bit difficult until you settle into your own routine. Good luck!
Can attest to the weight of the 200s, helped Verna load hers. Was surprised at the weight and size difference between hers and my 120s
In my estimation, a gen for A/C is impractical as you need to carry too much gas or be running for some on a regular basis.
2016 NuCamp 320 T@B Max S
T@bbey Road
Appleton, WI
T@bbey Road
Appleton, WI
aka BirdieJane towed by Quinn
