Careful - door latch loosens up!
ChanW
Member Posts: 3,171
A reminder to folks, that the door latch has been known to jam the door shut, with it unable to be opened without a locksmith (sometimes with the trailer occupied! argh!)
It might be caused by the latch loosening up in the door, in the way that I found the screw holding our latch in had backed itself out.
It just might have made the door stick shut, if the screw'd come out much farther. Don't really know, and don't really want to find out!
Tightened it up and secured it with a dab of LocTite.
Just an FYI...
Just an FYI...
Chan - near Buffalo NY
2014 S Maxx (ie: "320")2011 Tacoma 4cyl ... edit: 2022 Tacoma 6cyl - oh yeah!
2
Good point as I found that mine had loosened up too a few weeks back. Thanks for sharing Chan!Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ0
Before bedding down, please locate the emergency exits at the rear of the cabin. :-)
Or only use the window marked "emergency exit" only!ScottG said:Before bedding down, please locate the emergency exits at the rear of the cabin. :-)
Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ0 -
Isn't Chan the one who locked himself in the shower a few months ago?
Talk about bad Lock Karma!
2024 Ford F150 Supercrew short bed.3 -
Yup.. Happened to us too...Terry & Jody... 2025 Honda Ridgeline RTL
2016 NuCamp 320 T@B Max S
T@bbey Road
Appleton, WI0 -
Thanks for the support, TerryV6.
Noooo OutbackAZ, it was simply my imagination that locked itself in the 'head'! I have a bad habit of trying to be ready for any situation (takes up too much energy, honestly B-)
C'mon now, have you no imagination? It would be really hard to get out of that bathroom if you were trapped in there! I'm thinking that an emergency phone in the bathroom should be standard equipment! Someone should suggest it to LG.Chan - near Buffalo NY
A_Little_T@b'll_Do_Ya1 -
Just razz'n ya Chan! We all had a fun time with your post about the shower latch. You're a good sport.2016 Outback 320
Had the door latch problem too2015 CS. Ford f150 v8. Southern california0
Mine hasn't come loose... but it sticks pretty badly. Almost feels like it's locked & you got to pull fairly hard and it kind of pops open. Possibly a squirt of WD-40 will loosen a bit but I haven't had the chance to try yet. Is this happening to anyone else?2016 T@B silver Sofitel/Outback combo, 2012 Jeep Wrangler Sport TV, Kernersville N.C.0
ChanW, thanks for the heads-up mine was loose also!2016 T@B MAX S-aka: WolfT@B
Eric aka: Lone Wolf0 -
MrAmazon, see if you can see the place it's rubbing (look for a wear mark on there). It sounds more like it's binding, and wd-40 wouldn't fix that for long.
2016 model would still be under warranty.Chan - near Buffalo NY
Mine is tight--Thanks, Chan
Mine is too now, but I think it might be the wine.
A_Little_T@b'll_Do_Ya0 -
I haven't had mine yet, so it's not the wine
Mine is too, but it's beer related!
Eric aka: Lone Wolf1 -
After a glass of whiskey and a look around, I discovered I was also one screw short of a tight latch!
2015 Nissan Frontier SV V6 4x40
