Power Diagram
I found this diagram while I was studying about RV power systems.  There are a couple things that I think are incorrect.  Can those in the know chime in about what needs to be changed to reflect the Tab?
    That's a very generic diagram, but I'd say it reflects the T@B's layout pretty well--at least in terms of the major parts.
    If you are looking for real specific details, see Rick's diagram posted in this thread:
    http://www.tab-rv.com/forum#/discussion/comment/45261
    One question that I have is where in this diagram would the battery cut off switch be placed?  On the limb closest to the battery?  Just want to confirm.
    Uh-oh. That's a can 'o worms...  :-)
    I placed mine inside the camper, on the positive line from the battery, just before it enters the converter. Others have done the same, others have done differently.
    Almost any configuration works, just take the time to understand the benefits and limitations of each approach.
    The factory directs the dealers to place the cutoff switch at the battery.
    I have my battery switch at my battery, mounted to the tub cross support under the lid. I know there's a discussion I posted with my dual golf cart 6V batteries and cuttoff switch.
