jkjenn
Member Posts: 6,417
Also, for lubrication, I would recommend a white lithium grease, regular WD-40 is made for indoor use and will wash away in the rain. WD-40 actually makes a spray on white lithium grease that I have found works well. Use it on the BAL as well.
Sterling, VA
I was looking more to clean the unit and WD-40 is good for cleaning. I also carry white lithium grease to lubricate. I did not lubricate because it did not seem to need it. Maybe the answer is just a little spray with the garden hose.
Have not yet had a problem with the stabilizer coming down, maybe because I do not keep it as clean and lubed as well as I should.
Happy Trails Y'all
J.D. & Sue
