OK, maybe it's not that bad, but I don't feel very...comfortable right now. I have spent literally months reading this forum and making notes and checklists, but now my new 2016 T@B Outback is in the driveway attached to my TV and I'm thinking...now what? So I know that the first thing I need to do is to take it to a big lot and practice backing up, and I'm ready to do that starting tomorrow. But I'm not sure I have everything I need safety-wise or accessory-wise, and the dealer did a marginal job in showing me how to work everything and what I still might need to buy. I don't think this dealer has had a lot of experience with T@Bs and a lot of questions I asked him I don't think he'd ever considered. He didn't know about Alde fuses, he said he never has seen T@Bs fuses blow. I am just so inexperienced that I'm just afraid to do something wrong.
The dealer walk-through guy said that the diamond plate aluminum cargo box on the Outback was plastic. I knew then that I probably knew more about this thing than he did at this point. He also told me about encountering Big Foot when he was trailering in the northeast. And he was serious. So...you can imagine why I might be a little nervous he missed a few things.
My goal is to drive this from FL to West Virginia in about 2 weeks. So I want to be sure I have everything I need. I want to take it out in a few days and test-camp it at a local state park with hookups.
I bought a BAL leveler and brought it with me. The dealer had never seen one. So I have to figure out how to use it myself. He also did not go over how to determine level on the trailer. I think I know how to do that from the discussions here. The T@B looks a little like the back end is raised up more than it should be...? I have no way of knowing.
When I drove it home it seemed OK but it bumped up and down a little bit on occasion. I'm not sure if this is normal because I don't know what "normal" is yet. I unplugged the TV cord and set the T@B battery to off for the night.
The Trimax wheel lock I bought I think is the wrong size for the Outback wheels, which are larger (16"). But I don't know this for sure, maybe I'm just putting it on the tire wrong, but it doesn't seem to fit right. He also seemed to gloss over whatever other security things I might need. I plan to get one of those good locks for the trailer that others have mentioned here for when it is uncoupled from the car, but it would be good to know what to use when it's connected to the TV.
The accessory starter kit looks OK but I am not sure if I should get better hoses and connectors than what came with it. It is an EXCOUPLER RV ACCESSORY STARTER KIT.
Anyway...nervous about what I should do next. I guess I'm looking for some reassurance...or something.
0 ·
Check where you bought the tire lock from to see if it is supposed to fit your tires (I don't have an Outback).
I have the Rhino sewer hoses, a 15' and a 10' extension. A 25' white or blue fresh water hose is good, and don't forget a brass pressure relief valve.
There is a discussion that describes things that "newbies" should have. Pick and choose, and remember that Walmart or Campibg World have most items you'll need if you forget something. You really need to get a basic kit and then go camping. If you buy everything g everyone says to buy you'll need an extension to your tow vehicle
I guess I'm excited, but at the same time I'm just worried about doing something wrong/wrecking the thing, etc. It's probably just newbie nerves.
(As soon as one person mentions a particular brand, someone else will mention their favorite brand, by the way.)
You have the Bal, so you don't need Lego blocks.
You'll need chock blocks to put in front and behind the tires to keep it from rolling.
The stabilizers are at each corner of the T@B underneath. You should have a black long handled socket tool to raise and lower the stabilizers. You can get a packet of 4 plastic blocks to put under the stabilizers to keep the stabilizer pads from sinking into the sand, mud or some hot asphalt.
I recommend a Surge Protector. Do some reading here and decide how much you want to spend. Mine cost under $100
The very first thing to do, if you haven't done it, is to disconnect the trailer from your vehicle so the battery doesn't run down.
I swore I'd never, ever go camping - but I don't consider the T@B really camping - and I drove off the lot and started. There's nothing to get overwhelmed with.
Take it step by step and post whatever questions yo have here. We were all, at one point, going "what do I do now".
You'll be an old pro in no time. :-)
I threw my dealers dump hose in a dumpster. Specify exactly what you want your dealer to provide.
Buy two orange safety cones at HomeDepot and use them to practice backing up.
Put a spare set of keys (all of them) in your TV when camping.
Buy the following extended handle ratchet bar for use with your BAL leveler:
1/2 in. Drive 18 in. Ratcheting Breaker Bar
M@bel M@y, my 2017 T@B Outback Max S (silver w/black trim), towed by Maude Myrtle, my 2016 Jeep Rubicon Hardrock.
If you use a wag bag (or even double kitchen trash bags) in the toilet you can still use it without having to dump anything. If you want to practice showering just use water, no soap, and you can empty the gray tank on the driveway.
If you don't want to spend money on things like chocks and leveling pads, pieces of 2x4 work fine for chocks, and short wooden boards work for leveling pads.
I do recommend getting a 30a/15a adapter so you can plug the trailer into an outlet at your house, with a regular outdoor extension cord if needed. That will let you charge the battery and run everything in the trailer except the air conditioner.
You will likely make mistakes and may even break something. Things can be fixed. You'll learn as you go, and as you do you will become more comfortable with your new toy.
Def camp in your backyard, that's what I plan on doing the first night I get it home. There are a lot of 'beginner checklists' on here, Photomom and Jenn have posted some; good to print out & keep handy until you get all of your necessities. There are also checklists for hooking up to your campsite & for when you leave & pack up.
I have also learned from PXLated, as I gather my list o' stuff, to keep it simple.
Good luck & post some pics!
2017 t@b CS, silver with green trim.
TV: 2017 Honda Ridgeline.
Love the idea of practicing camping in the driveway, including trying out the bathroom, and then graduating in a few days to a local state campground where I can learn to pump the thing out. I am lucky enough to have a fairly secluded tropical driveway that is as pretty as anyplace in the area I could camp. The cord isn't long enough for me to plug in (though I do have an adapter already) so I will not be using the battery much, but I'll be trying out the propane for the water heater and the refrigerator. Should I buy a longer spare power cord? This one is 25'. It's a little too hot in Florida still for camping overnight but cooler weather will come soon enough. But I'm thinking maybe investing in a generator, which would come in handy anyway here in case we have hurricane power outages.
Definitely need lego blocks for under the stabilizers. I have not tried out the BAL yet but I did get an extension handle for it a while back at Wal Mart, thanks for the tip. I'll invest in better hoses based on what I've read here in the other forum threads. I'll also call about the Trimax lock to see if I got the wrong size, I think I did. But I can use it on my little boat trailer, so no harm no foul.
First things first though, gotta sign up for insurance today.
You all are great, thank you so much for helping me to feel a lot better today. I'm sure I'll have more questions. I have done a lot of reading on this forum so I'll try not to bug you too much. I did take a picture or two but need to make them smaller before I can post.
Big hugs to all, and if you are coming through SW FL, let me know. I can handle a boondock overnight for you!
The 30a extension cords and extra water hoses are pretty cheap, and we carry those now in case we need them.
Katie has made several long distance trips with out a problem. She and I would be happy to answer questions. We are over in Jupiter, are you anywhere close?
SweetlyHome, to answer your question, I am on the west coast of FL near Venice.
Others have probably said it already, but don't go off buying the world for your T@B, instead, get out there and camp. Figure out what kind of camping you prefer and start there, getting only what you need. And most of all, have fun!
Sterling, VA
We had the hitch problem as well. Working some lithium grease in and time solved the issue,
Now it's family.
Of course, this assumes you have properly chocked the trailer wheels. If you heeded my previous suggestions, you did this before attempting to unhook the trailer!
But here is the setback of the day.
The past few mornings I've been spending the early a.m. in the camper, catching up on news on the iPad, sipping coffee, enjoying getting to know my little space. Yesterday after doing this, I forgot to turn off the battery cutoff. I turned it off in the afternoon, so it had been set to ON for about five hours. Didn't think much of it because I'd turned everything off that I'd used, which just included the fan and the radio.
This morning when I went over to have my little morning retreat, the battery was dead. I thought, hmm...that shouldn't have happened. I'd turned everything off and it was just a couple hours.
Well, what happened is that the dealer walk through guy had set the Norcold to battery, didn't set it to off when I left the dealership, and I had not even noticed that. I hadn't used the fridge at all. I know from this wonderful group here that the fridge should be set to propane or shore power and never battery.
Anyway, bottom line is I now have a dead battery. Can I plug in to my home power using the adapter and an appropriate extension cord connected to the 30amp cord? Will this restore the charge?
Learning experience...for sure.
