I have been researching covers for my T@B.  Classic Accessories carries covers for the R-pod that should work.  They have one that fits a 13'1" x 6'6".  Do you think that will fit the T@B Outback?  My T@B delivery has been delayed until later this month so I can't measure the width.  They also stock a cover for a 16' 6" teardrop... wondering if that might cover the propane box and a spare tire I'm having mounted on the tongue.
Any advice would be most welcome.
                2017 white/black trim T@B Outback; 2017 white Subaru Outback; Seattle
0 ·
My *opinion* is because of all of the air space created under the cover at the front when extended out over the battery/LP box I would say 13' would be a fit on the length. It's close enough to where I might try it myself.
I think the 16.5' cover would be waaaay too big - it would extend out past the end of the tongue.
Hope this helps.
http://tab-rv.vanillaforums.com/discussion/comment/32640/#Comment_32640
2022 Ford F350 Tremor | 2022 Cirrus 620
In the pics I only had it pulled over the propane box, but now I keep it pulled over the ball coupling. It's gotten a few small tears, but nothing too serious. I suspect it will last about 3 years in our weather, but for the price, I think it's a good deal.
Just for clarification I was measuring only the body - bottom of trim to top of trim for purposes of using a cover. Measuring from the ground to the top of the vent cover is something entirely different - I think it's in the 93" range .
From the Classic Accessories website:
Specifications
*Total trailer length includes tow hitch
Which one did you get?
2016 Jeep Cherokee & 2017 T@B Outback
I've since replaced with the ripstop version, which is lighter and easier to put on. But it doesn't for as well, as it is for bigger rpods. It easily covers the tongue, but is a little wide. It works though, I can still enter the trailer, and I think it will last longer.
Classic Accessories OverDrive PermaPRO Deluxe R-Pod Cover, Fits up to 18' 8" long RVs - Lightweight Ripstop Fabric with RV Cover (80-255-151001-00) https://www.amazon.com/dp/B018M3JE8K/ref=cm_sw_r_cp_apap_FusaSb6MkUjQK
Was it in full sun all last summer?
2017 T@b 320 - 'Smokey' 2017 Toyota Tacoma TRD Sport - 'B@ndit'
Dave - Tuscaloosa, Al
