A question for those of you who store your T@Bs away from home over the winter: Do you leave the battery in your trailer or remove it?
Feel free to comment.
        Remove battery or not? 25 votes
                    I charge the battery fully, leave it in the T@B, and forget about it till Spring.
                             1 vote
                            1 vote
                    I charge the battery fully, leave it in the T@B, and check the charge level periodically.
                    I remove the battery, store it in a protected area, and put it on a trickle charger.
                    Something else (explain in comments.)
0 ·
2019 Ford F-150 3.5L Ecoboost with Long Bed
Be aware that a trickle charger is not the same as a smart charger. A garden variety trickle charger should not be left hooked up any longer than it takes to top up the battery. True smart chargers adjust their output as needed to prevent battery damage. You can leave these hooked up full time, but I've never found a compelling reason to do so.
Certainly you can store your battery in the warmth of your home or in your basement as others do, but IMHO this isn't necessary if the battery is in good health and has been fully charged up in late fall, prior to the onset of cold weather and winter conditions. I wouldn't leave the trailer plugged into shore power full time either (as there is wear & tear on the electric converter) and if I felt the need I would buy a battery tender and use that rather than risking the electric converter.
Also, the old wives tale of placing a battery on top of a piece of wood is just that - an old wives tale! There is no discharge or issue with placing a battery on a concrete surface as the exterior of batteries are plastic, which insulates it from earth or concrete and concrete does not impact the rate of electrical discharge in a battery as the plastic insulates and eliminates the problem as you probably already know.
https://www.amazon.com/dp/B005EKY1EM
I'm not familiar with that particular brand. If you are looking to drop that kind of coin, I hear Ctek makes a top notch unit. I have one, but I also have a $15 bargain basement charger that seems to do the job just as well.
But I live in midland NC which has a mild winter. No problems so far after 5 years. Knock on wood!
2011 T@B
Rockingham, NC
2014 T@B CS Maxx
Martha Lake, WA
https://www.google.com/search?q=coleman+sunforce&client=safari&sa=X&hl=en-us&biw=414&bih=628&tbs=vw:l,ss:9&tbm=shop&prmd=svin&srpd=12390493673330904494&prds=epd:7628613294366301988,paur:ClkAsKraX4E9m2Z9XU6_sxOr40xDMdUN60D2y41PWXg8F6ZIEuBf-aYochwaAXAZEuumJprd_uWLpJWsGLHab1wsS-ZEW1UtRGxMclIEubIcN5Rv17ZzBayp7xIZAFPVH707BlZ1Mw-Ez4HpAbZKX6aVzIJUog,cdl:1,cid:13267627646549843388&ved=0ahUKEwib0fqajNTPAhVLrlQKHYToAzIQgTYIngMwAA
