FuzzyYanni
Member Posts: 110
3 Way Norcold 3163LGH26R - No Ticking Igniter Troubleshooting
Our 3-way doesn't work on propane, the igniter doesn't even make that ticking sound when you switch to propane at all.
I will need to troubleshoot, hopefully without removal from the back of our T@DA. (Update YUP - did NOT have to pull the fridge]
Tested this theory in our T@B (Where the 3 way fridge works perfectly and it does in-fact tick)
Click here to listen to a properly working fridge and the "ticking Igniter" from our T@B
I will also be cleaning the orifice burner while I am at it, and replacing the thermocouple. It works perfectly on AC and DC and the fridge is silent, I love this fridge.
Parts Ordered:
Norcold Refrigerator Electrode with Wire 617966 $21.08
Norcold 621951 Burner-Orifice Assembly (Amazon) $35.78
Norcold 617983 RV Refrigerator Thermocouple $22.76
Total parts (including shipping) $87
I downloaded the service manual which has a troubleshooting decision tree (I call it a logic diagram).
It's been uploaded to this forum here: http://tab-rv.vanillaforums.com/discussion/3878/norcold-removal-cleaning-pdf-files#latest
Went through the appropriate section and determined everything is working except the igniter. Disconnecting the igniter from the circuit as per the instructions reveals the circuit board is still ticking correctly when wire near a ground.
I found a bunch if pictures online showing how to remove the fridge from a Westy. Very cool
I believe the igniter must have a short or grounding itself out thus no ticking. So I will be replacing the igniter (or simply un-grounding it) and probably the thermocouple and burner orifice while I'm at it.
I will investigate more and report Back. Maybe I will do a video.
he
I learned that the hard way-- the 3-way Nor-Cold in our T@B was my first real experience with that type of fridge. You should have heard our converter/charger squeal when we finally plugged in, with a darned-near (if not) totally-discharged battery. Dark, in the rain, in a small campground in New Brunswick. Took quite a while before it quieted down so we could sleep. Now THAT was a learning experience! (After that, I ran it on propane over the road.)
Remember on 12V it runs at 100% power all the time, the temperature setting doesn't work! It's all or off. (scratches head)
yannisfyssas@gmail.com
https://goo.gl/photos/6LuHbX3YxLG7qwDr8
You're still at the servicing place, correct? Please keep us posted!
I'll just throw out one other thought, though it probably doesn't apply here: when the folks who bought our T@B were looking at it, I tried to get the fridge to run on propane. Same thing; green light would come on, but shut down within seconds of releasing the button. Tried several times, no go. Took it home to get it ready for pick up (it had been on display a few miles away), and realized I had left Chan's bug-deterrent cover on! As soon as I removed that, the fridge worked just fine on propane. It just need that air in & out of the concentric intake/exhaust vent. Oops. One more lesson..doh!
http://webs.lanset.com/rcochran/norcold.html
