@ChanW, Yes, the fridge being on F6 seemed wrong to me as well, and I have not traced the wires, but it only turns off when that fuse is pulled out, so there's a relationship there, but I agree, it seems suspicious, which fuse is yours on?ChanW said:AldebaranJill, your diagram is great. Very interesting to see. Thanks for sharing your research.
I'll have to see if we have the same model WFCO, and see what its output is, at various states of charge. You've got me curious now!
You have 'Fridge' on F6, the battery charger fuse. That confuses me. Is that right?
Also,which model Noco Genius did you use?
@SAM Hmmmm, that's a good question. I suppose you can't. Handy Bob says "Buy AGM only if you cannot get at them for maintenance or cannot vent" so I followed that advice and didn't pursue AGM..SAM said:Wow, Jill! I have read Handy Bob as well. If you can't rely on voltage as a measure of charge, and must check the sp. gravity, how do you measure state of charge with an AGM? So, the Noco effectively functions as an AC charge controller much like a solar charge controller in that it helps regulate the voltage that charges the battery?
Sharon
Just to be clear, the WFCO converters are "a good 3 stage charger"ColoradoJon said:
Just confirming - if you disperse camp make sure to fully charge your battery with a good, 3 stage charger!
@ScottG After many discussions with Handy Bob, I decided not to pursue solar until after I had fully gotten my battery charging solution and TriMetric wiring totally redone. When the dealer installed the TriMetric, they put it under the seat and tapped into my system in a location where (because of the T@B wiring) missed ALL of the loads on the blue wire! So I have not pursued solar yet, because so far, with a fully charged 100AH battery and being able to precisely see how many A each appliance uses, I haven't had to revisit solar.ScottG said:Thanks for the excellent explanation, @AldebaranJill. Through this board (and the school of hard knocks) I learned a lot about battery management when I got the T@B two years. However, I'm only a running a basic system with a group-27 flooded cell and 100W solar panel, so most of the high-capacity/high-tech stuff is still a mystery to me.
Do you use solar at all, or do you rely solely on your high capacity for multi-day dry camping? If you do use solar, do you experience the same issues with inadequate charging voltage?
@ColoradoJon Battery debates do seem to get really passionate. People kept telling me the WFCO 8735 was working just fine, and that may be the case, it's just that it was not able to fully charge my batteries, which leads to early battery demise. Without support from my local battery dealer and Handy Bob, I would never have found a solution, and would have just kept killing batteries, year after year.ColoradoJon said:Mmm hmm! I had the same problem with the built in converter on my 2017 not being able to fully charge my dual 6V setup. I mentioned something about it in a previous post and was met with... um... resistance from others.
I use a Pro-Logix PL2320 charger now for battery charging. The converter only runs lights when I am home and connected to power
Suspicious of this statement, I contacted WFCO and they confirmed a typo in both the manual and in the online FAQ. "Bulk mode" activates when the battery voltage drops below 12.2 volts (not 13.2 volts).rfuss928 said:...
Bulk Mode: When the converter senses that the RV system voltage is
less than 13.2 Vdc (equivalent to less than 50% of battery charge), the
converter will automatically go into the “Bulk mode.”
Maybe you don't get by--it's all just a lie based in self-deception and denial. ;-)Nomad said:Sorry, no offense but I read these threads and wonder how in the heck I get by with my little battery and minimalist, stock set up. :-)
2007 T@B
Rockford, IL
