Eagle eyes there, Tabber! Good job.TabberJohn said:Compare Photomom's thread photo versus Eddy's above.
The end of Eddy's glycol drain tube has been torn off. The tube should be longer with a brass plug in the end.
Sure looks that way, but it's hard to tell for certain which tube is which. The configurations are clearly different in the two photos.TabberJohn said:Compare Photomom's thread photo versus Eddy's above.
It is located just below the Alde unit.Photomom said:If you look at the floor inside you should be able to match up the drains there with the tubes under the trailer and figure out which is which.
TabberJohn said:What year is your CS-S?
I see what you mean now by enlarging your photo. There is a green fluid drip line on the larger tube.
The smaller ones looks a bit ragged, but it is unclear what's what.
@ ScottG: I will check that in a couple of days, once I'm back home. I'm on a business trip nowScottG said:That still leaves the million dollar question... Did you locate the tube with the brass plug? Was it intact.
