No problems here on Safari. Apparently last night there were probably updates made to the forum software because I had to log into each forum, but that happens every week or so.
Verna, Columbus, IN 2021 T@B 320S Boondock “The T@B” Towed by a white 2019 Ford F-150 4x4 Supercab, 3.5L V6 Ecoboost “The Truck”
Safari is really strict on login cookies if you run the default preferences. Go to: Safari Menu -> Preferences. Click the Privacy Icon. Check the Always allow radio button under 'Cookies and website data'. You will be able to login after doing that.
When my ipad is slow to load, I end up Clearing History and Website Data on Safari. It works, but of course I then need to login again...Pxlated, I used your recommended Crop Size app for this!
Wether you can see sigs or not depends on how you have it set in your profile - Click on your name at top, then edit profile - it's a drop-down under that little profile graphic. There will then be a list of things like signature in the right hand column you can choose/edit.
OK, I can't see anybody's signatures. My signature profile has "Hide signatures always" checked and you can see mine??? This is on the PC and ipad - what's up with that?
I use Safari and frequently have trouble logging into this forum, probably after updates. I found that I can log onto the Little Guy forum, then I'm back in business here.
Gil Butler, Folsom, CA, 2015 T@B M@XX CS - White with Yellow tim
For Safari on iPhone/iPads ... Either of the last two coices are fine...Suspect same on desktop...
Correct, both of the bottom options are essentially the same. I use 'always allow' as it is no less secure than the option above it yet has fewest problems with cross URL cookies.
Sterling, VA
