We hooked up a charger to our T@B battery today in the garage. The battery still read 12.7v but when we examined the water levels before hooking it up we noted that the 3 cells on the + side were low and needed water. The 3 cells on the - side were at the normal level.
Can someone explain?
0 ·
I'm not sure if differential off-gassing among cells means anything. I've noticed that dying batteries "boil" more when being charged, so maybe it's a sign that those cells are a little more tired than the others. Either way, I'd just top 'em up (use distilled water) and go on my merry way. If your battery can still take and hold a charge, then it's still got life.
I have no idea what this means, or if it's normal. I've found no guidance from googling either...
2014 T@B CS Maxx
Martha Lake, WA
Also I think that the more you charge the battery at a high rate, the more the electrolyte will boil, and lose water.
Photomom, are you using an 'external' charger to keep your battery topped off? Maybe it's over-charging? Or maybe you discharge your battery more than we do. Ours seldom needs water (annually at most). We only charge the battery with the Tab's system, and keep it plugged in pretty steadily.
e.g. http://www.samsclub.com/sams/duracell-agm-golf-car-battery-group-size-gc2agm/prod3870119.ip?mobiledetect=false
J.D. & Sue
We have some nasty weather coming so we got out today and hooked up the charger. Before we did we checked the voltage, still 12.7v, and checked the water level in the cells. We were surprised to see that the water level in 3 of the cells had dropped since the end of Oct with the battery just sitting there with no load.
My procedure: check fluid level, add water if necessary to bring fluid at least 1/8" to 1/4" above plates. Charge. After full charge cycle disconnect battery and let rest one hour. Top off water. Done.
@DurangoTab - AGM batteries are excellent, maintenance free batteries. They do require a higher charge voltage and are more expensive than comparable flooded acid batteries, though. The one you linked is 190 amps (20 hour rate). And, AGM batteries can be laid on their side!
I have not heard sounds while discharging, and my battery manual states to fill water only after full charge, so must not expand or be too gurgly during discharge.
But if you want maintainance free, or to have them inside the cabin, or lay on side, they seem like a good option to consider, but there may be an AH capacity trade-off depending on brand. Of course if you have two 6V, you are swimming in capacity! If and when mine eventually goes, I would certainly consider two 6V under a seat if I could not fit outside.
For more info: Click Me
The marine battery you have is a hybrid - cross between 20 hour capacity and cold cranking amps. For most people these batteries work well, especially if you have solar recharging.
Sorry I cannot say much about them. They are new to me
I got the idea for this installation from someone else on this forum, but I don't recall who. Feel free to PM me if you want more details.
Thank you, is it this one?
