I winterized today but I'm using the heat tonight. I have heat, but I was thinking when the unit kicked on that the pump indicator starts spinning on the electronic control.I used the blow out method, the water heater is empty. I'm on 120 power electric only. It could just be me thinking the symbol used to spin as the unit kicked on.  The pump indicator is comming on but it's not spinning, am I dreaming that it used to? I don't want to damage anything.
                0 ·
Linden, VA
2016 T@B Q Max Outback Package - 2015 Toyota Tacoma TRD Off Road
Shenandoah Valley T@BBERS
I also just finished winterizing using the RV Fluid and bypassing the Alde water heater. I drained the Hot water before winterizing.
I want to be able to use the propane or electric to run the heater a few times this winter. From the reply it sounds like it is acceptable to do this without damage to the unit. Correct?
Thanks,
Janet
Perfect. Thanks for the quick reply. Enjoy the day.
That brass thing - ya, gets warm but it doesn't get hot enought to start a fire. As I recall though, some that were concerned put a piece of aluminum faced insulation between it and the cushion fabric.
That black vent is aux air intake for the air conditioner. There's a fan switch left of the Alde controls that activates it. The Alde vent is next to the shore power plug on the drivers side.
Running Alde with cover on - You probably could if the vent was exposed. Some run an extension cord to a small quartz heater.
If the hot water tank is full, the heaters heat both the water in the tank, and the glycol the cabin heat loop. If the hot water tank is empty, only the glycol is heater.
So, nothing prevents the Alde from trying to heat the hot water, but as others noted, it won't hurt anything to do so!
