Looking for best practices to flush the black water/grey water tank (mine is combined). One of those wands or the clear elbow fitting or ? Looking for actual experience, not theoretical
Thanks!
0 ·
https://www.amazon.com/Valterra-SS01-Boxed-SewerSolution-System/dp/B00CCYWJQK/ref=sr_1_1?ie=UTF8&qid=1485015995&sr=8-1&keywords=sewer+solution
2022 Ford F350 Tremor | 2022 Cirrus 620
https://www.amazon.com/gp/aw/d/B008O9DV78/ref=mp_s_a_1_8?ie=UTF8&qid=1485209350&sr=8-8&pi=AC_SX236_SY340_QL65&keywords=rv+tank+flush&dpPl=1&dpID=41d9qzPJodL&ref=plSrch
Question, though... When you're back-flushing your black tank, what's to keep the black tank from eventually filling up and overflowing into the RV?
Also, would it be worthwhile to reverse flush the gray water tank?
Thanks for any info, RVs are new to me and I don't know much about plumbing. :-)
It seems the only way a 'reverse flush' would work is if a second person stood in the Tab, watching through the open toilet drain.
I'm also not sure what the point is to the reverse flush method.
The gray tank flush is easier, because you can run water into the sink, while watching the shower drain for over-filling.
I saw those, but they only really do one round and they don't use any enzymes.
I backflush all of the time and have never had a problem with it overflowing into the RV.
I have the same set up and I use the Rhino Blaster. As far as I can tell it works fine.
https://www.etrailer.com/RV-Sewer/Camco/CAM39080.html
Evanston Wyoming home
i have a hose dedicated just for this task.
With the “Flush king” attached I first drain the tank. Then I close the value on my “Flusk king” and open the black tank value. I then turn on the water supply attached to the “Flush King”. I watch my tank Gauge. When it gets to 90% I turn off the water. I then open the value to the tank and check the contents. Repeat until the water coming out is clear.
