We are purchasing a tab max S within the next couple of months and would like to purchase a 2017 ford escape 2.0L ecoboost (3500 lb towing capacity). Does anyone know if this vehicle is capable of towing easily through the mountains? Thanks for any help.
0 ·
The 2017 model is 245/279 with an improved engine design (carbon deposit issue resolved).
There are a plenty of T@B owners pulling with a lot less power than that.
AWD is your best option (not technically 4WD).
Sterling, VA
"Growing old is mandatory. Growing up is optional."
Sterling, VA
2017 T@b 320 - 'Smokey' 2017 Toyota Tacoma TRD Sport - 'B@ndit'
Dave - Tuscaloosa, Al
For the 2013-2016 Ford Escape there was nearly no mechanical difference between the tow package and those without. Just the wiring, the hitch, and electronic sway control. A certain percentage of the internet thinks that you can add the wiring/hitch after you buy and still tow 3500.
On the 2017 Escape the actual radiator fan/cooling is different when you get the tow package. This would indicate that, unless it comes from the factory with the tow option, you won't be able to reach 3500 by just adding a hitch/wiring.
[Insert 800 caveats and 6432 Internet flame wars about how much you can safely tow under what conditions.]
They are both pretty interesting & inexpensive for the small trailer cohort.
I have a 2014 Ford Escape Ecoboost -- I believe it is a 2.0 engine with FWD.
A. Do you think this car can handle the T@B
B. Do I need to get a brake controller?
https://www.ford.com/resources/ford/general/pdf/towingguides/14prelimflrv&tt_escape_may13.pdf
Thanks to all!
So I ordered a hitch today and I asked installer for 7 pin wiring
He mentioned something about 7 Blade -- is this the same thing?
Adventures: 51 Nights: 322 Towing Miles 41,200+
