Just curious to know what make/model compressor you all use to blow out your water lines? I'm planning on taking R@nger out in a few days so will need to de-winterize. In Alabama, temps fluctuate wildly this time of year so it is quite possible that I will have to winterize again and I will use the blowout method instead of antifreeze. I know some of you even use a bicycle pump. How do you connect to the blowout plug? I will have to do this by myself.
                2017 T@b 320 - 'Smokey'
 2017 Toyota Tacoma TRD Sport - 'B@ndit'Dave - Tuscaloosa, Al
0 ·
I have a portable Vair for the road and then 6 gallon Bostitch compressor for at home. The bigger one is great because it fills tires and blows out the lines much faster than the portable.
To dewinterize I just flush they system with fresh water, sanitize it, and then flush again. It is best to do that at a place where you have city water and can open up your gray tank. The compressor is not needed for that operation.
Sterling, VA
2017 T@b 320 - 'Smokey' 2017 Toyota Tacoma TRD Sport - 'B@ndit'
A diluted bleach solution is used (it takes very little bleach, ¼ cup to every 15 gallons of water), poured into the fresh water tank. Use the water pump to pressurize the system, opening each valve (sink, shower) until you smell the bleach.
Once pressurized I usually drive it around the block a few times to also mix it up in the fresh water tank. Let it sit for ½ hour, then drain and flush it.
It should be done once a season, usually as part of the dewinterization process.
Sterling, VA
But honestly, the extra concentration is probably not enough to do any damage, so I just use it stronger and give it a really good rinse to get rid of it all.
2014 T@B CS Maxx
Martha Lake, WA
Janet
2017 T@B Outback
Tehachapi, CA
2017 T@B Outback
TV 2012 Nissan Frontier
Tehachapi, CA
Yes, you want to make sure that you do t exceed 50 psi. You can use the same regulator you use for your hose for city water, too.
It is my experience that the small 12V tankless compressors for tire inflation do not produce enough flow to "blow out" much of anything. They are capable of making high pressure but , very slowly.
I would be inclined to try an air mattress inflater or the output of a shop vac if I didn't have a large enough air compressor.
SUNT@B's simple system just drains when I open a valve on the bottom so I have no experience with the LG T@B plumbing systems. I do have a seasonal cabin with plumbing that has to be winterized.
2011 T@B
Rockingham, NC
It has a built in restrictor (not regulator) that slows the volume of incoming air down to almost a trickle. Using the alde's 2 gallon tank volume as an air buffer, I let it bring the entire system to 50 psi (takes about 20 seconds), then proceed to open each valve to blow out all the water. I'll do this cycle 3-4 times, or until all I get is hissing air. Done!
My compressor has a regulator that I set to 50 for this procedure.
This method also works great with one of those 12v auto or bike tire pumps and the appropriate fitting. Just takes a lot longer to wait for the system to reach 50 pounds.
2014 T@B CS Maxx
Martha Lake, WA
