Check Your Television Attachment
Carolyn
Member Posts: 129
When we were traveling back across the country to Florida after Tabazona we opened the camper door to find the television on the floor. I had never checked the connection at the top of the swivel that holds the television to the wall but the bolt had worked loose and dropped the television to the floor. Some of the connections are broken or stripped but the screen appears to be okay. we have not tried to hook it back up yet. I now know to check that periodically!
2014 CS, tie-dyed exterior, "Tabula Rasa" and 2009 T@da also tie-dyed, “Grateful”
2
Maybe you should stick one of these on the back of your T@B...
The bolt that holds our television to the bracket worked loose too. Fortunately the strap that holds the television in place while traveling kept it from falling. I've since replaced the bracket. Couldn't ever get the factory installed one to not work itself loose.2014 T@B-S
2019 Honda Ridgeline, AWD, V6, 5,000 lbs towing capacity
Minnesota0 -
I was thinking of replacing the bracket. What did you replace it with?2014 CS, tie-dyed exterior, "Tabula Rasa" and 2009 T@da also tie-dyed, “Grateful”0
Ordered this one
from
Parts Expresss: https://www.parts-express.com/dayton-audio-shadow-mount-lcdart-articulating-arm-tv-wall-mount-up-to-30-lcd--182-3702014 T@B-S
Minnesota0 -
Mine seems weak to me, when I tilt it and I have also thought about replacing it.
Ours always flopped around a bit, I thought more than it should. I found that tightening the pivot screw fixed it.
It's seemed way more solid now.Chan - near Buffalo NY
A_Little_T@b'll_Do_Ya1
