First Solo Drive, Facing Down the Fears
I need to replace my pneumatic jockey wheel tire and would like to replace it with a heavy duty industrial unit. How would I find such a unit? I'm not sure how to get the new tire on the wheel. Do I take it to a tire shop? Obviously starting from ground zero here with my knowledge of how things work.rfuss928 said:
My original pneumatic jockey wheel tire degraded very quickly developing leaking cracks- cheap Chinese tire. It was common for many other owners to fill them with Slime flat prevention fluid or replace them with another tire and wheel. I replaced mine with a heavy duty industrial unit.
A cover would help prevent the degradation but sounds inconvenient.
My spare is mounted to the side of the tongue box using the original bracket from the bottom of the T@B. There is less space on the tongue of my CS model than other DM models like yours. There is possibly room for another type bracket on your frame. It seems I remember some suggestions on the Yahoo forum.Katt and Miss Cannoli the Zen Dog
2008 DM T@DA — Towed by 2014 Dodge Durango — Full time since 6/29/17
"Travels With The Tiny"0 -
It does take a bit of mechanical aptitude to adapt another wheel and tire to the Alko bracket. You will probably need a 5 inch long bolt either 5/8" or 3/4" diameter for an axle. A tire something like this would be appropriate. The "universal fit" parts solve some of the adaptation problems.
http://www.ebay.com/itm/Marathon-Universal-Fit-Pneumatic-Air-Filled-Hand-Truck-Utility-Tire-on-Wheel/322415174762?_trksid=p2047675.c100005.m1851&_trkparms=aid=2220072&algo=SIC.MBE&ao=2&asc=41395&meid=beadfbfb0c854fe08f3ef506e3b0a4f8&pid=100005&rk=2&rkt=6&sd=122043656184.
Not necessarily a recommendation, just what I found doing a quick search on your behalf.
Have fun!!
Well, how kind of you! I found something with the same numbers on it: 3.00-4 and 260x85. So maybe I'll give it a shot. Thank you!!! http://www.ebay.com/itm/3-00-4-Scooter-Tire-Inner-Tube-Set-Pocket-Bike-3-00-4-10x3-260x85-/282064319469?hash=item41ac57f3ed:g:Jh0AAOSw241YYhVd&vxp=mtrrfuss928 said:It does take a bit of mechanical aptitude to adapt another wheel and tire to the Alko bracket. You will probably need a 5 inch long bolt either 5/8" or 3/4" diameter for an axle. A tire something like this would be appropriate. The "universal fit" parts solve some of the adaptation problems.
Have fun!!
That looks like a great choice. Anyone that has changed a bicycle tire should be able to change the tire. You may have to cut the valve out of the hole in the wheel if it is a tubeless style like my original.
@rfuss928 You gave me a GREAT idea. When I get the new tire, I'll take it and my wheel to my local bike shop!
"Travels With The Tiny"1
