Any suggestions on how to keep the cabinet lid from slamming shut on your knuckles while trying to put stuff in or out of that long cabinet in the back of the max S.  If I can't figure it out I will have to name our new unit "blueknuckle".  Also, we have been trying to stick baskets, etc. to the wall using those sticky hooks.  It makes a lot of noise when the fall off.  I hate using screws, especially in the bath but it looks like that is the permanent solution.???
                0 ·
Not sure of your setup, but I found really nice struts that hold up all my under seat storage lids (that I've added hinges to). If this would work, let me know and I'll find the link. I got four of them for under $20 via Amazon. Superb quality.
I know that Command makes specific strips for wet environments (bathrooms) and they also make a picture hanging strip that's extra large that is spec'd at 16 lbs if you use four of them.
Sterling, VA
Actually, this got me thinking. Has anybody modified (or thought about modifying) the back shelf in a 2015 or older in order to gain a little storage from that otherwise dead space underneath?
And, yes, I did use piano hinges and I left a space at the rear for the heat to escape. As I recall, the exterior measurement was 6" deep.
Thanks, @Verna . I wonder if that plywood could or should be replaced with some type of grate?
Does the area under the driver send bench get hot, as well, or not as much because it can vent. I am also thinking of these containers under there for storing extra cords. I have an over-abundance of cords.
Yes, as I recall, your T@B is configured just a bit differently than mine.
Ed at the factory told me they use 1/2" foil faced insulation on the bottom of the boxes. I was unable to find any smaller than a 4'x8' sheet. I'll kerp looking
HD has the 1/2" foam and you could probably wrap in foil. (http://www.homedepot.com/p/R-Matte-Rmax-Plus-3-1-2-in-x-4-ft-x-8-ft-R-3-2-Polyisocyanurate-Rigid-Foam-Insulation-Board-754404/100572981)
