I'm going to install a hitch mount for my spare tire so it sits perpendicular to the trailer; (e.g. straddles the front of the trailer).  I'm trying to decide whether to get the mount that attaches to the jack or whether to have one welded closer to the battery/propane storage box.  Although I don't have to worry about hitch weight (I tow with a large truck), I am curious whether or not there would be an impact on handling whether the tire sits closer to the hitch or closer to the trailer.  Does anyone have any thoughts on this?  Are there any other factors to consider in the decision; (e.g. access to the storage box, etc.)
                2022 T@B 400 BD
2019 Ford F-150 3.5L Ecoboost with Long Bed
0 ·
Alan & Patty
Southern Az
The Outback accoutrements would certainly add a few pounds. The state of your holding tanks, and (as PXL mentioned) how much you load behind the axle will also have an impact.
2022 Ford F350 Tremor | 2022 Cirrus 620
"Growing old is mandatory. Growing up is optional."
I'm thinking that the only way to put it on is the way they did it. The whole assembly has to be mounted backward.
