https://www.eventbrite.com/e/ucamp17-the-annual-gathering-of-tb-tg-and-teardrop-enthusiasts-registration-33116827322Read and register for the first uCamp17, proudly sponsored by nuCamp, The Annual Gathering of T@B, T@G and Teardrop Enthusiasts
Jeannie
Sterling, VA
Jeannie
I trust Solarites will be basking in the sun and a swarm of generators humming by day 5.
What is the 7-AMP service used for?
And it could be like 2014 at Tearstock in August when it was in 40's at night, upper 50's, lower 60's during the day and I had all shorts, one long sleeve shirt (lots of shorts sleeved shirts) and one sweatshirt. We all huddled around the Little Red Campfire at night!
We do?
I actually am not sure how to check what number I was in signing up.
Sterling, VA
When you click on register, there is a number count for how many sites are left.
Sterling, VA
Sterling, VA
Thank you!
2016 CS S, 2008 Toyota Tacoma
Somerset, VA
It is not be enough amps to run anything except maybe a small fan--check the amperage on any electrical fans you'll be bringing. It will not be enough for air conditioning (A/C), microwave, hair dryer, toaster oven, toaster, etc.
Somerset, VA
I have a wonderful O2 fan that has 3 choices for powering it and it decides which is most economical: batteries, rechargeable batteries or being plugged into a USB port that also recharges the internal batteries. It is wonderful! I may get another one of them as they are investments into camping in AZ.
I use solar power power for most of the winter, so using solar is easy for me. Conserving battery and energy is also second nature to me. I am the most economical of 100 houses of the approximate same size in my area.
Everyone will be having fun and from the looks of the satellite images, there are lots of trees to sit under.
Somerset, VA
