Sharp edges on shower door & molding?
drpprmt
Member Posts: 117
Has any one else found the sharp burrs on the top of the shower door and aluminum molding?
Not so far. Is it the corner or the top, and what year model? I'd imagine a dremel with a sanding bit would alleviate the problem.2017 T@B 320-S, Sofitel (M@bel)
Mabel is my great grandmother that I never knew. She took her 3 sons (ages 8-2) on an epic adventure from Alabama to Florida in the 1930's in the back of a pick up truck. I named my female English springer spaniel after my mother. Might as well go for broke with the brownie points in Heaven!
TV: 2018 Ford F-150 Lariat Supercrew
David & Jill, Houston, TX -
Back in 2015, Bert's Labrador got a cut on his back from the bottom of the door-needed stitches! Verna recommended using a fine file to smooth them down. She did throw that issue back to Pleasant Valley, now nuCamp.John, Judi, Guinness & OD in PDX
T@Bit@t 2015 S Max Outback, ‘18 V6 4Runner -
We have a new 2017 S model. The top of the aluminum metal on the jam, door frame, and hinge were not finished smoothly. They had sharp burrs. Of course the jam is a perfect place to rest your hand when going into the shower room. Big mistake. Fixed jam with a file and hand with a bandage. Hope people do a quick check so they don't find out the hard way.
drpprmt said:We have a new 2017 S model. The top of the aluminum metal on the jam, door frame, and hinge were not finished smoothly. They had sharp burrs. Of course the jam is a perfect place to rest your hand when going into the shower room. Big mistake. Fixed jam with a file and hand with a bandage. Hope people do a quick check so they don't find out the hard way.
Problems like this should go back to your dealer to fix, who should take it back to nuCamp. And yes, a simple file will take care of the sharp edges. I extend my apologies from the factory.Verna, Columbus, IN
Mine had sharp edges on the top and I filed them down.
Gotta love the dremel tool. So many uses!!!2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)
I filed mine down, too. It took about 5 minutes.Verna, Columbus, IN
- 919 Introductions
- 74 Teardrop Groups & Links
