How much stuff do you carry in your T@B ?? - Cargo Weights
rfuss928
rfuss928 Member Posts: 1,197
edited April 2017 in Trailer & Towing
I recently had the unique opportunity to see exactly how much stuff we carry in our T@B.
SUNT@B needed a new floor and it had to be empty to begin the replacement.
We keep the camper ready to go anytime.  So other than our cloths bags and perishable foods, everything is on board.
Everything was removed and placed in plastic bins, boxes and baskets then set aside to be reloaded later.
As I re-equipped the completed trailer, I weighed everything!
I will preface the results with the perspective that we are very lightweight campers having used a tandem bicycle as our RV for many years prior to SUNT@B.  When we attend rallies or gatherings of similar campers, we clearly are at the less stuff end of the spectrum. The interior and kitchen are ready to use even when we are on the move because nothing has to travel in the living spaces.
That being said, this is what I found:
sub-total
orig equip
INTERIOR
288
Batteries 120 120
60
Porta Potty with water 31
Closet shelves 7
Front shelves 12
Front upper cabinet stuff 15
75 foot 12-3 extension cord 9
30 foot 30 amp extension cord 8
BatteryMinder 3
Front trunk organizer 15
Vacuum cleaner 5
Electric heater 3
Flower power awning 17
Visor XL 5
Texsport  hatch shelter 5
Extra hoses, broom, brush 5
Brakes, bearings, jack, air pump 22
candles, patio lights 5
spare parts boxes 6
Steps 15
Grills 11
Stabilizer crank 2
2
Folding chairs
19
Charcoal, bucket 13
Table 35
35
Slats 14
14
Patio mat 6 X 9 6
TONGUE BOX
90
Chocks, blocks, Drill, lock,lighter 23
10# composite LPG tank - full 20
20
5# steel LPG tank - full 15
Rubber mat 2
BAL leveler 16
25 foot 30 amp service cord 9
9
30 foot fresh water hose 5
KITCHEN
174
Box 1 - upper cabinets 19
Box 2 - under sink 16
Box 3 - Pots & pans cabinet 28
Flatware, utensils, teapot, towels 21
10 gallons of fresh water 80
Plasticware  7
Wine sign & mat 3
CUSHIONS & BEDDING
95
Cushions -  5 each 20
20
Memory foam & cover 24
Pillows 9
Sheets & towels 20
Comforter & pad 10
Rugs 6
Towels 6
TOTAL
767
160
NET ADDED WEIGHT
607
Over 600 pounds!!!
I'm sure there is easily another 100 pounds of clothing, toiletries and food items to be added before we drive away.
The back of the TV has two plastic totes of supplies, a cooler and a tool bag.  The back seat is Bella's.
With the 1680 pound empty trailer weight there is nearly 2400 pounds total not including any of the weight in the TV.
Something to compare to your own "list" and consider when choosing TVs
Have fun!  Travel safe!
  • wizard1880
    wizard1880 Member Posts: 442
    edited April 2017
    Depending on model and year/month of manufacture, you get either a 2800, 2900 or a 3500 lbs axle.  Our early 2014 CS (not wetbath) model came with the 3500 axle, and even with 15 inch tires! It depends on what they have available at the factory at the moment of manufacture.
    T@@bulous
    2014 T@B CS Maxx
    Martha Lake, WA
  • Smullis7
    Smullis7 Member Posts: 221
    I had to unload mine to send it in for repairs from hail damage...an entire reskining.  I carry way more than I thought I did...
  • Mouseketab
    Mouseketab Member Posts: 1,262
    edited April 2017
    Also note that Dutchmen T@Bs max out at 1930. Most of the stuff on your list I keep in my tow vehicle. I travel  with no water in my tank and just a small bit in my portapotty. The chairs, rugs, spare tables, awnings, cooler, bucket of extension cords, BAL Leveler, tools, and food box all go in the back of the truck. I have gotten rid of the original table. I weighed mine at a truck stop fully loaded about 5 years ago, and I was at 1950, so I am over weight, but not by much. I need to weigh again and adjust now that I've added the power mover.
    Carol
    MOUSE-KE-T@B
    2022 nuCamp T@B 320 CS-S
    Harvest, AL
  • rfuss928
    I took SUNT@B to the scale today and with everything listed above on board it weighed 2280 pounds.
    Subtracting the measured added weight of 607 results in an empty weight of 1673 pounds.
    The weight and capacity sticker on the T@B says 1680.
    Now that's unbelievably close!
  • Ratkity
    Ratkity Member Posts: 3,770
    Wow!! So many manufacturers understate their trailer weights (meh - the give or take 10% rule). For people with smaller TVs and are tentatively upgrading to a bumper pull where weight is crucial, I agree!! Unbelievably close. Part of the refreshing honesty and customer awareness we all know and love.
  • dsatwork
    dsatwork Member Posts: 744
    edited April 2017
    Weight and where you position it, is important for Tab owners and especially those of us with Tab 320 S models. I'm not sure about the clam shells and the Tab's without a shower seem to have adequate storage in the front.  However, the Tab's with a shower, it seems that most of the available storage is behind the axle. Then compound that problem with this being a light trailer that is attractive to midsize SUV's owners that have limited tongue weight. When you combine these it's really important to know how much your trailer weighs and where it's located. We have all seen the video demonstration of what happens if there is too much weight in the back of your trailer. The first time I towed the Tab, I was shocked how rear-end heavy it felt compared to towing my little guy 5 wide, where most of the storage is on the platform up front. So, with my 2016 Sorento V6 AWD's 5000 lbs tow capacity and a 500 lbs tongue weight, I decided to swap out the standard battery tub for a larger box. With the larger box I was able to have two 100AH AGM batteries the standard propane tank and a place to mount the spare on the side of the box. I'll also be carrying a honda generator on the tongue for a total tongue weight of 315 lbs. This weekend were taking it up to the mountains for our final shakedown trip. I need to see how it tows with the added weight on the tongue before we head out on our 3,144 mile trip in late May early June. We'll be going from San Diego to Yellowstone to Mt Rushmore then back through Colorado to San Diego.
  • Photomom
    Photomom Member Posts: 2,217
    How do you know which axle you have?
  • rfuss928
    edited April 2017
    I thought some folks might find this useful in estimating/realizing how much weight they add to their vehicles (TV & T@B) loading up all their stuff.  It is not real specific for many items but makes one think about the kitchen cabinet full of pots and pans could easily be 30 pounds.  Almost 100 pounds total goes into our kitchen not including food and water. The same thing with bedding, mattress topper and towels..
    Add to my list some very common accessories like a side tent, gas grill, Coleman stove, E-Z up, dutch oven, bicycles.......
    It is really ill-advised to think a TV with a 2000# rating will be adequate especially for a "newbie" with no towing experience asking for advise.
    Be smart.
    Be safe.
    Most of all - Have fun!
  • dsatwork
    Be smart.
    Be safe.
    Point well taken and one I personally had to struggle with because I had a lot of faith in my 2008 CR-V especially the way I had the rear suspension beefed up. Ultimately I decided it would be best to have more than needed. Now, I'm thrilled with the possibility the larger tow vehicle gives me.
  • wizard1880
    There is a sticker attached to the frame, facing outwards near the front jack.  It's fairly easy to find.  I'm not at home otherwise I'd put a picture of mine and where to find it.  I'll try to do that this weekend.
    T@@bulous
    2014 T@B CS Maxx
    Martha Lake, WA
  • wizard1880
    Here's mine.  It also state's your tire size, though in my case it is incorrect:
    T@@bulous
    2014 T@B CS Maxx
    Martha Lake, WA
  • wizard1880
    And here's where it can be found:
    T@@bulous
    2014 T@B CS Maxx
    Martha Lake, WA
  • Sprockethead
    Sprockethead Member Posts: 13
    sub-total
    orig equip
    INTERIOR
    288
    Batteries 120 120
    60
    Closet shelves 7
    Front shelves 12
    BatteryMinder 3
    Vacuum cleaner 5
    Electric heater 3
    Visor XL 5
    spare parts boxes 6
    Steps 15
    Grills 11
    Stabilizer crank 2
    2
    Folding chairs
    19
    Charcoal, bucket 13
    Table 35
    35
    Slats 14
    14
    Patio mat 6 X 9 6
    TONGUE BOX
    90
    20
    Rubber mat 2
    BAL leveler 16
    9
    KITCHEN
    174
    Plasticware  7
    Wine sign & mat 3
    CUSHIONS & BEDDING
    95
    20
    Pillows 9
    Sheets & towels 20
    Comforter & pad 10
    Rugs 6
    Towels 6
    TOTAL
    767
    160
    NET ADDED WEIGHT
    607
    Over 600 pounds!!!
    This is Exactly why I don't tow my 20' Rpod anymore!, Objects in the Mirror are larger than they seem... My 2016 4Runner V-6 seemed Overworked.
    2019 T@B 320S Boondock Edge, Factory 133 watt solar, 215ah AGM
  • Mouseketab
    So aren't you now overweight, since you have an Al-Ko frame that maxes out at 1939?
    Carol
    MOUSE-KE-T@B
    Harvest, AL
