How much stuff do you carry in your T@B ?? - Cargo Weights
rfuss928
Member Posts: 1,192
I recently had the unique opportunity to see exactly how much stuff we carry in our T@B.
SUNT@B needed a new floor and it had to be empty to begin the replacement.
We keep the camper ready to go anytime. So other than our cloths bags and perishable foods, everything is on board.
Everything was removed and placed in plastic bins, boxes and baskets then set aside to be reloaded later.
As I re-equipped the completed trailer, I weighed everything!
I will preface the results with the perspective that we are very lightweight campers having used a tandem bicycle as our RV for many years prior to SUNT@B. When we attend rallies or gatherings of similar campers, we clearly are at the less stuff end of the spectrum. The interior and kitchen are ready to use even when we are on the move because nothing has to travel in the living spaces.
That being said, this is what I found:
Over 600 pounds!!!
I'm sure there is easily another 100 pounds of clothing, toiletries and food items to be added before we drive away.
The back of the TV has two plastic totes of supplies, a cooler and a tool bag. The back seat is Bella's.
With the 1680 pound empty trailer weight there is nearly 2400 pounds total not including any of the weight in the TV.
Something to compare to your own "list" and consider when choosing TVs
Have fun! Travel safe!
| sub-total | orig equip | |||
| INTERIOR | 288 | |||
| Batteries | 120 | 120 | 60 | |
| Porta Potty with water | 31 | |||
| Closet shelves | 7 | |||
| Front shelves | 12 | |||
| Front upper cabinet stuff | 15 | |||
| 75 foot 12-3 extension cord | 9 | |||
| 30 foot 30 amp extension cord | 8 | |||
| BatteryMinder | 3 | |||
| Front trunk organizer | 15 | |||
| Vacuum cleaner | 5 | |||
| Electric heater | 3 | |||
| Flower power awning | 17 | |||
| Visor XL | 5 | |||
| Texsport hatch shelter | 5 | |||
| Extra hoses, broom, brush | 5 | |||
| Brakes, bearings, jack, air pump | 22 | |||
| candles, patio lights | 5 | |||
| spare parts boxes | 6 | |||
| Steps | 15 | |||
| Grills | 11 | |||
| Stabilizer crank | 2 | 2 | ||
| Folding chairs |
19 | |||
| Charcoal, bucket | 13 | |||
| Table | 35 | 35 | ||
| Slats | 14 | 14 | ||
| Patio mat 6 X 9 | 6 | |||
| TONGUE BOX | 90 | |||
| Chocks, blocks, Drill, lock,lighter | 23 | |||
| 10# composite LPG tank - full | 20 | 20 | ||
| 5# steel LPG tank - full | 15 | |||
| Rubber mat | 2 | |||
| BAL leveler | 16 | |||
| 25 foot 30 amp service cord | 9 | 9 | ||
| 30 foot fresh water hose | 5 | |||
| KITCHEN | 174 | |||
| Box 1 - upper cabinets | 19 | |||
| Box 2 - under sink | 16 | |||
| Box 3 - Pots & pans cabinet | 28 | |||
| Flatware, utensils, teapot, towels | 21 | |||
| 10 gallons of fresh water | 80 | |||
| Plasticware | 7 | |||
| Wine sign & mat | 3 | |||
| CUSHIONS & BEDDING | 95 | |||
| Cushions - 5 each | 20 | 20 | ||
| Memory foam & cover | 24 | |||
| Pillows | 9 | |||
| Sheets & towels | 20 | |||
| Comforter & pad | 10 | |||
| Rugs | 6 | |||
| Towels | 6 | |||
| TOTAL | 767 | 160 | ||
| NET ADDED WEIGHT |
607 |
Over 600 pounds!!!
7
Depending on model and year/month of manufacture, you get either a 2800, 2900 or a 3500 lbs axle. Our early 2014 CS (not wetbath) model came with the 3500 axle, and even with 15 inch tires! It depends on what they have available at the factory at the moment of manufacture.
I had to unload mine to send it in for repairs from hail damage...an entire reskining. I carry way more than I thought I did...Sheila and the Mullis Pups (Winston, Morgan, Leroy & Dakota)
M@bel M@y, my 2017 T@B Outback Max S (silver w/black trim), towed by Maude Myrtle, my 2016 Jeep Rubicon Hardrock.
Also note that Dutchmen T@Bs max out at 1930. Most of the stuff on your list I keep in my tow vehicle. I travel with no water in my tank and just a small bit in my portapotty. The chairs, rugs, spare tables, awnings, cooler, bucket of extension cords, BAL Leveler, tools, and food box all go in the back of the truck. I have gotten rid of the original table. I weighed mine at a truck stop fully loaded about 5 years ago, and I was at 1950, so I am over weight, but not by much. I need to weigh again and adjust now that I've added the power mover.
Carol
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL0 -
I took SUNT@B to the scale today and with everything listed above on board it weighed 2280 pounds.
Subtracting the measured added weight of 607 results in an empty weight of 1673 pounds.
The weight and capacity sticker on the T@B says 1680.
Now that's unbelievably close!
2 -
rfuss928 said:I took SUNT@B to the scale today and with everything listed above on board it weighed 2280 pounds.
Wow!! So many manufacturers understate their trailer weights (meh - the give or take 10% rule). For people with smaller TVs and are tentatively upgrading to a bumper pull where weight is crucial, I agree!! Unbelievably close. Part of the refreshing honesty and customer awareness we all know and love.2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)0 -
Weight and where you position it, is important for Tab owners and especially those of us with Tab 320 S models. I'm not sure about the clam shells and the Tab's without a shower seem to have adequate storage in the front. However, the Tab's with a shower, it seems that most of the available storage is behind the axle. Then compound that problem with this being a light trailer that is attractive to midsize SUV's owners that have limited tongue weight. When you combine these it's really important to know how much your trailer weighs and where it's located. We have all seen the video demonstration of what happens if there is too much weight in the back of your trailer. The first time I towed the Tab, I was shocked how rear-end heavy it felt compared to towing my little guy 5 wide, where most of the storage is on the platform up front. So, with my 2016 Sorento V6 AWD's 5000 lbs tow capacity and a 500 lbs tongue weight, I decided to swap out the standard battery tub for a larger box. With the larger box I was able to have two 100AH AGM batteries the standard propane tank and a place to mount the spare on the side of the box. I'll also be carrying a honda generator on the tongue for a total tongue weight of 315 lbs. This weekend were taking it up to the mountains for our final shakedown trip. I need to see how it tows with the added weight on the tongue before we head out on our 3,144 mile trip in late May early June. We'll be going from San Diego to Yellowstone to Mt Rushmore then back through Colorado to San Diego.2017 Tab Basic S Silver on Silver with Sofitel Cushions....upgraded from 2013 LG 5W....Towed by a 2016 Sorento V6 AWD w/5000lb tow capacity. Dave S. married to Jen aka SanDiegoGal We pull a Tab but live in a 2014 Airstream International Signature 27 FBQ...Talk about embracing a trailer lifestyle.2
wizard1880 said:Depending on model and year/month of manufacture, you get either a 2800, 2900 or a 3500 lbs axle. Our early 2014 CS (not wetbath) model came with the 3500 axle, and even with 15 inch tires! It depends on what they have available at the factory at the moment of manufacture.
How do you know which axle you have?John and Henrietta, Late 2016 T@B S Max in Western New York0 -
I thought some folks might find this useful in estimating/realizing how much weight they add to their vehicles (TV & T@B) loading up all their stuff. It is not real specific for many items but makes one think about the kitchen cabinet full of pots and pans could easily be 30 pounds. Almost 100 pounds total goes into our kitchen not including food and water. The same thing with bedding, mattress topper and towels..
Add to my list some very common accessories like a side tent, gas grill, Coleman stove, E-Z up, dutch oven, bicycles.......
It is really ill-advised to think a TV with a 2000# rating will be adequate especially for a "newbie" with no towing experience asking for advise.
Be smart.
Be safe.
Most of all - Have fun!
2 -
rfuss928 said:I thought some folks might find this useful in estimating/realizing how much weight they add to their vehicles (TV & T@B) loading up all their stuff. It is not real specific for many items but makes one think about the kitchen cabinet full of pots and pans could easily be 30 pounds. Almost 100 pounds total goes into our kitchen not including food and water. The same thing with bedding, mattress topper and towels..
Be smart.
Be safe.
Point well taken and one I personally had to struggle with because I had a lot of faith in my 2008 CR-V especially the way I had the rear suspension beefed up. Ultimately I decided it would be best to have more than needed. Now, I'm thrilled with the possibility the larger tow vehicle gives me.2017 Tab Basic S Silver on Silver with Sofitel Cushions....upgraded from 2013 LG 5W....Towed by a 2016 Sorento V6 AWD w/5000lb tow capacity. Dave S. married to Jen aka SanDiegoGal We pull a Tab but live in a 2014 Airstream International Signature 27 FBQ...Talk about embracing a trailer lifestyle.0 -
There is a sticker attached to the frame, facing outwards near the front jack. It's fairly easy to find. I'm not at home otherwise I'd put a picture of mine and where to find it. I'll try to do that this weekend.
Here's mine. It also state's your tire size, though in my case it is incorrect:
And here's where it can be found:
2 -
rfuss928 said:I recently had the unique opportunity to see exactly how much stuff we carry in our T@B.
That being said, this is what I found:sub-total orig equip INTERIOR 288 Batteries 120 120 60 Porta Potty with water 31 Closet shelves 7 Front shelves 12 Front upper cabinet stuff 15 75 foot 12-3 extension cord 9 30 foot 30 amp extension cord 8 BatteryMinder 3 Front trunk organizer 15 Vacuum cleaner 5 Electric heater 3 Flower power awning 17 Visor XL 5 Texsport hatch shelter 5 Extra hoses, broom, brush 5 Brakes, bearings, jack, air pump 22 candles, patio lights 5 spare parts boxes 6 Steps 15 Grills 11 Stabilizer crank 2 2 Folding chairs 19 Charcoal, bucket 13 Table 35 35 Slats 14 14 Patio mat 6 X 9 6 TONGUE BOX 90 Chocks, blocks, Drill, lock,lighter 23 10# composite LPG tank - full 20 20 5# steel LPG tank - full 15 Rubber mat 2 BAL leveler 16 25 foot 30 amp service cord 9 9 30 foot fresh water hose 5 KITCHEN 174 Box 1 - upper cabinets 19 Box 2 - under sink 16 Box 3 - Pots & pans cabinet 28 Flatware, utensils, teapot, towels 21 10 gallons of fresh water 80 Plasticware 7 Wine sign & mat 3 CUSHIONS & BEDDING 95 Cushions - 5 each 20 20 Memory foam & cover 24 Pillows 9 Sheets & towels 20 Comforter & pad 10 Rugs 6 Towels 6 TOTAL 767 160 NET ADDED WEIGHT 607
Over 600 pounds!!!
This is Exactly why I don't tow my 20' Rpod anymore!, Objects in the Mirror are larger than they seem... My 2016 4Runner V-6 seemed Overworked.2019 T@B 320S Boondock Edge, Factory 133 watt solar, 215ah AGM0 -
So aren't you now overweight, since you have an Al-Ko frame that maxes out at 1939?Carol
MOUSE-KE-T@B
Harvest, AL0
- 30 "FOR SALE" - New/Used Trailers
