Hydro Flush question
mickietucs
Member Posts: 720
For those using the hydro flush - thinking I'm not using it right (even though the hose water pressure seems strong enough) because I let it "back flush" and think the tank is clean but then I followed that procedure up with going inside the bathroom and turning the hose on strong inside the toilet - and when I go back outside to release the valve, I see it was definitely not cleaned out with just the hydro flush. So what am I doing wrong? I'd rather not have to clean both ways (then why use the hydro flush?) --- any tips/tricks?
Oh, and I do fill toilet with at least 1-2 gal of water after each dump (understand water is a toilet's best friend)!
And on a side note, when I dump and get to the grey water, I find that stinks way more than black. I've put grey water treatment in the sink (and the smell isn't IN the trailer - only when I dump) --- I've tried various grey water treatments so would appreciate any thoughts on this as well (I have a sink strainer and I always wipe dishes/pots/pans with paper towels beforehand).
Bleach is always your friend for eliminating odors."Great spirits have always encountered violent opposition from mediocre minds." Albert Einstein
2015 T@B M@X S White with Grey trim | TV 2021 Ascent Touring | Flagstaff AZ. -
larrygon said:Bleach is always your friend for eliminating odors.
Unless you are allergic to it.. then it's sorta a frienemy.2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart) -
Might try a tad bit of bleach..
I was still hoping someone uses the Hydroflush and could give advice on using it ---- ???Michele, Tucson, AZ. TV - '13 F150 & '16 T@Bitha special order.
You never really travel alone. The world is full of friends waiting to get to know you! -
I tried HF on last rv and mostly a gimmick. Had better luck rinsing from inside with hose. A bag of ice in the toilet on the way home does wonders
Thank you Newfisher --- I wondered if I wasn't using it correctly.Michele, Tucson, AZ. TV - '13 F150 & '16 T@Bitha special order.
I actually had good luck with mine until I changed to the single discharge. It's not at the right angle now to shoot into the black tank. I always kept the non-potable hose on top for the maximum force of spraying water into the black tank.Verna, Columbus, IN
Verna said:I actually had good luck with mine until I changed to the single discharge. It's not at the right angle now to shoot into the black tank. I always kept the non-potable hose on top for the maximum force of spraying water into the black tank.
Verna - what's "the single discharge"? Your point, though, about the angle - perhaps that's what I need to look at and think I can hook it up so the hose is on top (will look at it again next time I dump).Michele, Tucson, AZ. TV - '13 F150 & '16 T@Bitha special order.
@mickietucs, it seems I can never remember the correct term:
http://tab-rv.vanillaforums.com/discussion/3453/single-black-and-gray-water-drain-setup#latest
Instead of separate "drain pipes" for black and gray, Dale changed mine to be a single drain pipe which is so very helpful.Verna, Columbus, IN
Verna said:@mickietucs, it seems I can never remember the correct term:
Verna - Now I understand (and your terminology makes sense). I will attach the HF next time so the hose part is at the top and see if that helps at all. Thanks!Michele, Tucson, AZ. TV - '13 F150 & '16 T@Bitha special order.
Michelle, I am fairly liberal with my water to waste ratio as I flush after using the toilet. This is one of the essential elements of good black tank use. I also back flush a few times, when I have the time and no one is waiting behind me. Lastly, a good tank treatment like Happy Campers or your favorite gel packs really help, too.mickietucs said:For those using the hydro flush - thinking I'm not using it right (even though the hose water pressure seems strong enough) because I let it "back flush" and think the tank is clean but then I followed that procedure up with going inside the bathroom and turning the hose on strong inside the toilet - and when I go back outside to release the valve, I see it was definitely not cleaned out with just the hydro flush. So what am I doing wrong? I'd rather not have to clean both ways (then why use the hydro flush?) --- any tips/tricks?
@Verna - That tip about positioning the back flow/hose to be at the top did the trick - it seemed to clean out much better. I also used a stronger force with the hose. Thanks!
@jkjenn - I've used the Happy Campers stuff and also like it, however, those gel packs I think do a great job (in combination with keeping a gal or 2 in the tank after I dump).Michele, Tucson, AZ. TV - '13 F150 & '16 T@Bitha special order.
Yes - I agree! The gel packs work great, too. They are stronger in smell but easier to use on the road.mickietucs said:@Verna - That tip about positioning the back flow/hose to be at the top did the trick - it seemed to clean out much better. I also used a stronger force with the hose. Thanks!
I searched for black tank care and saw someone advocated adding a couple trays of ice cubes to the tank via the toilet. then he drove around about 15 miles or so and drained the tank and flushed again. The theory I guess is that the chunk ice cubes sort of scrubbed the sides of the tank. Have yet to try it. Just an idea I guess.
2018 T@B 400, 2017 Nissan Titan Crew cab -
Urban legend.atlasb said:I searched for black tank care and saw someone advocated adding a couple trays of ice cubes to the tank via the toilet. then he drove around about 15 miles or so and drained the tank and flushed again. The theory I guess is that the chunk ice cubes sort of scrubbed the sides of the tank. Have yet to try it. Just an idea I guess.
https://www.youtube.com/watch?v=iH6acEmqvcw
IMHO based on a You Tube test that I viewed It was ineffective at best.
- Hash T@B Fun
- 919 Introductions
- 74 Teardrop Groups & Links
