We have had our t@b Outback for two weeks and the mods proceed! I got thinking about the extra space in the electrical compartment.
There is a ton of extra space but it is almost impossible to use.
My solution was to add a "lip" around 3 sides that allows us to use this space for a (oddly shaped) toolbox.
The toolbox rests on the "lip" on three sides and is tight to the wheel well. I also added two XLPE foam blocks to the floor under the toolbox to ensure adequate support.
The toolbox dimensions and shape were determined by existing wiring and allowing for adequate clearance for heat dissipation.
The toolbox is not fixed in any way but is easily lifted out to access the electrical. Not exactly fine woodworking but extremely functional. Fits a surprising variety of items.
And the final touch was to add the piano hinge for easy access.
Super pleased with the results.
Let the mods continue!
Cheers- James
Are you going to put a strap somewhere so you can lift it out? You don't have any by-pass valves in there, so I guess it's not a major deal.
2016 Jeep Cherokee & 2017 T@B Outback
"Growing old is mandatory. Growing up is optional."
Materials are 3mm and 6mm baltic birch and 1x 2,3,6 pine
@jkjenn "Lip" is easy to create using off the shelf house framing straps from any big box bandit. Cheap too!
@dsatwork Of coarse I made scale drawings in Solidworks and subjected it to FEA analysis thus determining the need for 3.6 lb high density cross link foam of sufficient surface area to conform to ASTM 4169 .
Busted... yeah, I winged it.
@ericnliz Aww shucks.. Thanks.
I am, however, a pro at stripping Phillips head screws at the worst possible moment. It's a gift.
Ut oh hymie, we may have the same genetic anomaly! I've even busted 2x T45 Torx bits. I now have a manual impact drill that should knock those Harley Torx bolts loose without breaking bits (the bolts themselves are almost indestructible). My very old mobile home I lived in when in grad school used Robertson (square) heads. Never seen them before that. Never really saw Torx much either. Seeing more of both lately.
tv 2010 Lexus RX350 Matador red
I'll try for some photos in a different post this afternoon. It's just a start with only the wire baskets right now. I've used two fake wicker boxes for two years and wanted something more permanent and something easier to see my food stuffs. I need to turn the Alde and fridge on today so I can work in there plus hopefully the camp hostess Campground might get my campsite electrical ready so I can finally start my "job" this weekend;). (I'm actually calling it a fun summer, not a job!)
However....
It is a PIG at 6 amps. So likely use will be when on shore power and for very limited use on battery.
All in all- worth it for us. It was the smallest physical choice at the big box bandit near me.
I finally switched to a good black and decker 12v vacuum. I found it worked well and I could recharge either via the T@b or while driving.
2014 T@B CS Maxx
Martha Lake, WA
Well, you start with a pool noodle... hehehehe.
Or, as I like to call it, the "Whirling Vortex Of Death". Somehow that seems to make it a little more final...
